Planning a system
Username: Davidt487
Post Number: 33
I've planned out my new system and wanted to get some feedback on choices.
fishercustoms box 1.9cuft 35hz
hifonics bxi2006d
re audio sx 12 dual 2 ohm
just wanted to see if there are any other good ideas b4 i spend the money?
Username: Logan__tille
HEMIKLR
Post Number: 9105
Sounds good. Where do you plan on buying the sub and amp from?
Username: Davidt487
Post Number: 34
ive got the amp although im think the ed nine.1 might be better for me and the sub off ebay $250 shipped
Username: Skibum12189
Cleveland
Post Number: 2288
yes on the nine.1>hifonics
Username: Davidt487
Post Number: 35
well i just bought the hifonics because i got a good deal on it but i was thinking maybe i'll ebay it and get a nine.1
Username: Davidt487
Post Number: 36
here is the box
its for a 2005 chevy silverado single cabUpload
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 1204
u might wanna make the top of that box 7 inches wide,the sx 12 has a mounting depth of 6.5 inches,6 inches wont cut it,unless u use a spacer ring
Username: Davidt487
Texas
Post Number: 37
ive got an alpine type r and its in a sealed box that is the same depth wise with a trim ring and its mounting depth is like 7 11/16 so i dont think i will need it this time
