Silver Member Username: TornPost Number: 451 Registered: Jan-07 | In the guts of the amp is there's a switch labeled on the board Air Bass and left position that it came in as is Labeled Out and the other position is labeled in, the tool is pointing to it. Wtf this do>? |
Gold Member Username: camBC Canada Post Number: 1460 Registered: Nov-06 | http://www.soundstream.com/manuals/other/airbass/airbass.pdf That might help. I skimmed through it, but it doesn't look like it could have any effect in your issue. |
Gold Member Username: camBC Canada Post Number: 1461 Registered: Nov-06 | You could try switching it to "In", and see if that helps. I can't see how you could do any damage to it, but wait for someone with experience with 'em. This post is more of a bump with a little content. |
Silver Member Username: TornPost Number: 452 Registered: Jan-07 | Yea looked into that and the original that came with the amp, says nothing about it in the original. Also tried it switch to the other but same thing. |
