Bronze Member Username: Vic123TorontoCanada Post Number: 32 Registered: Jul-06 | guy my viewsat is down all I see is 4 dots on my display..what should i do...where can i get viewsat loader2 ?? please help |
Silver Member Username: RunnerguyPluto Post Number: 958 Registered: Sep-06 | totalfta dot com |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 2425 Registered: Sep-06 | https://www.ecoustics.com/electronics/forum/home-video/424720.html the loader is on just about every forum around if you cant find i let me know |
Bronze Member Username: Vic123TorontoCanada Post Number: 33 Registered: Jul-06 | FTA TESTER there is loader1 cant find loader2 where can i get tht? Im using the regular loader but the % stays 0 |
Gold Member Username: SatgrlPost Number: 1197 Registered: Oct-07 | its called loader2 u can get it at...might wanna register..than use link |
Gold Member Username: SatgrlPost Number: 1198 Registered: Oct-07 | WARNING: Use all files at your own risk. IMPORTANT: Attachment Issues? Click Here Loader_v11.zip (407.1 KB, 3483 views) Loader2.zip (70.0 KB, 2236 views) ViewsatPVRLoader.zip (486.5 KB, 943 views) |
Gold Member Username: NydasPost Number: 6533 Registered: Jun-06 | THERE'S SOMETHING WRONG SOMEWHERE I am not sure why a member of over a year's standing is asking where to get a loader file. I am not sure why a Viewsat Ultra owner is asking for a loader file when he should be using $10 USB drive. |
Bronze Member Username: Vic123TorontoCanada Post Number: 34 Registered: Jul-06 | nalin nyda thats coz my receiver is frooze all i can see on my display is 4 dots and when i trying it to load from serial port it remains at 0% doesn't go any future..can u hep why is it satying at 0%? |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 2439 Registered: Sep-06 | yes nalin their is something very wrong when a user with a thread count of 6500 did not read the thread first. the user can not use a usb drive when the receiver is in that state. |
Gold Member Username: SatgrlPost Number: 1200 Registered: Oct-07 | u need to load the factory bin for it i think u did something wrong while loading.. |
Bronze Member Username: Vic123TorontoCanada Post Number: 35 Registered: Jul-06 | yea and when im trying the serial port it remains at 0% |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 2440 Registered: Sep-06 | vic have you rebooted the host computer? yes satgirl is right you will need to do factory bin first viewsatusa.com for it |
Gold Member Username: NydasPost Number: 6534 Registered: Jun-06 | THE FTA TESTER : Criticism accepted. Did not read the question - just the heading and the word Loader. |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 2444 Registered: Sep-06 | Thats ok we all do it from time to time |
Bronze Member Username: Vic123TorontoCanada Post Number: 36 Registered: Jul-06 | how am i gonna load when it doen't load its remainsss at 0% doen't move from 0%..it says sending and then resending but doesn't load? |
Gold Member Username: NydasPost Number: 6536 Registered: Jun-06 | I hope you are using a Null Modem cable |
New member Username: Bin_aladdinPost Number: 2 Registered: Dec-07 | same problem here with new bin...just froze on upgrade and got the 4 dots now. It wont even power ON... So the factory bin with Null Modem Cable is my only option? Then I put new bin again? Thanks |
