B-80
Username: Mamporeros0379
Post Number: 16
Hello hope you all had a Merry Christmas. I tried to download the B-80 on my pansat 3500 but i keep getting the B-70 on the display. i have read the instructions about 20 times & have tried about 40 times. Thank you
Username: Quetoidalat
use cable 232 null to load
Post Number: 17
Is that the same cable that i use to load the bins on my 3500 or the cable i use for my 2500
Username: Ke5aqn
Post Number: 2407
Have you rebooted the host computer?
Post Number: 18
my actual computer?
Username: Ke5aqn
Post Number: 2409
yes the computer that the receiver is connecting to...
cable 2500= straight
cable 3500= null
Load B 80 by cable 232 null If you have problem of receiver , reset computer, do again
