Username: Mamporeros0379 Post Number: 16 Registered: Nov-07
Wednesday, December 26, 2007 - 16:00 GMT Hello hope you all had a Merry Christmas. I tried to download the B-80 on my pansat 3500 but i keep getting the B-70 on the display. i have read the instructions about 20 times & have tried about 40 times. Thank you
Username: Quetoidalat Post Number: 1 Registered: Nov-07
Wednesday, December 26, 2007 - 16:06 GMT use cable 232 null to load
Username: Mamporeros0379 Post Number: 17 Registered: Nov-07
Wednesday, December 26, 2007 - 16:10 GMT Is that the same cable that i use to load the bins on my 3500 or the cable i use for my 2500
Username: Ke5aqn IF I DONT KNOW THE ANSWER,
I WILL FIND...
Post Number: 2407 Registered: Sep-06
Wednesday, December 26, 2007 - 16:12 GMT Have you rebooted the host computer?
Username: Mamporeros0379 Post Number: 18 Registered: Nov-07
Wednesday, December 26, 2007 - 16:15 GMT my actual computer?
I WILL FIND...
Post Number: 2409 Registered: Sep-06
Wednesday, December 26, 2007 - 16:26 GMT yes the computer that the receiver is connecting to...
Username: Quetoidalat Post Number: 2 Registered: Nov-07
Wednesday, December 26, 2007 - 16:50 GMT cable 2500= straight cable 3500= null Load B 80 by cable 232 null If you have problem of receiver , reset computer, do again
