Help, wierd sound coming from speakers and deck ejecting CD
Username: Shiok
i need help here, i have bought a deck.
its a Sony CDX L490X. i have a 1991 nissan pulsar. i removed the old deck by just cutting off the wires. the wires from the car are coloured: BROWN, RED, YELLOW, BLACK, BLACK+WHITE, BLACK+WHITE,BLACK+PURPLE.
i am very confused to which wire goes with which wire on my new deck...
for some reason, the sound is very weird and echoey..Also, whenever i on my ignition, the deck will power on, and eject the cd!! please help.
this is what ive done: i connected yellow,red (from sony) to the Brown. White+Black(sony) to black+purple. white(sony) to black+white. grey+black(sony) to black+white. grey(sony) to yellow.
the sound is pretty stuffed up... but i tried connecting a speaker directly to the sony's grey and grey+black wires and the sound is GOOD!
so which means i am doing something wrong about the wiring,...please help, ive searched many websites trying to find wiring diargrams for my car.
thanks
Username: Shiok
oh by the way, the deck dosnt remember the radio stations that i have set after i off my engine and on it again.
Username: Shiok
argh...i cant figure it out,i dont know what is the brown wire..... i dont wanna trial and error, i tried that earlier and i blew a fuse
Username: Glasswolf
Post Number: 436
you don't match colors
I'm surprised you didn't fry the radio yet.
take it to a professional and have it installed.
Username: Shiok
ok, i finally got it right, everything works ok now!
i didnt match up the colours properly...i wanted to do it myself, because firstly, im a uni student, and only working casual shifts, thus...cant really afford to spend few hundred bucks for installation...
Username: Glasswolf
Post Number: 452
the thing is colors don't match up.
you need to get the color codes for your specific make/model/year of car, and the color codes for the head unit, then put the right wires together.
you don't match red to red, blue to blue, etc.
that's how ya blow things up :-)
I just hooked up my system And it sounds good except when i i really turn up the deck i get a crackle sound from the 10m inch kenwwod i have. This mostly occurs from burned cds. I am running a 600w kenwood amp with 8 gauge wire from battery an I have 16 gauge speaker wire from amp to the my 600w kenwood 10. What is causing the destortion
Pete
jason- you're going to either have to get the radio installed professionally or get a multimeter from radio shack.
you need to test the wires and connect them after you know what they are.
yellow- constant 12v
red - switched 12v (12v when ignition is on and 0 when key is removed.
Black - ground
Blue - power antannae
blue/white - amp turn-on
white and white black - front left speaker + and -
Gray and gray/black - front right speaker
Purple and purple black = rear right speaker
green and green/black = rear left speaker
those are the essential wires from the sony deck.
-Pete
flex
pete i really don't understand what you ment by yellow-constant 12v. do u mean that yellow should be connect to yellow and red connect to red?
please let me know.
Username: Tyblu
flex, if you get the proper wiring harness for your car it will be colour coded. $10 well worth it.
Joey
How do you test the wires with a multimeter, what reading am i supposed to expect? I got a VT commodore and i got the same problem, i dont know which wire goes where.
