Wiring Amp
Username: Clemsonfan151
I recently got a new amp that I'm going to use to power my subs. It is capable of running at 4.2,1 ohm (like most are). My subs are 2 ohm models. I was just wondering if it is possible to connect both of my 2 ohm subs to my amp in a way that make it put out a 2 ohm signal.
Thanks.
Username: •cam•
BC Canada
Post Number: 1391
The signal isn't 2 ohms.
Two 2 ohm loads wired in parallel will yield a 1 ohm load.
Maybe I'm not explaining it right.
The amp puts out 550 watts at 4 ohms
1100 watts at 2 ohms
and 1600 watts at 1 ohm.
The subs need 500 watts each.
I just want to know if it is possible to wire the subs so that they recieve 500 watts.
Username: •cam•
BC Canada
Post Number: 1392
Nope. Run it at 1 ohm with the gains down.
Welcome to the forum!
Username: Ctmike
Ct.
Post Number: 5614
what amp is it?
It's the Hifonics Brutus 1606D.
So there is no way to wire the subs so that they take advantage of the 2 ohm capabliity of the amp?
Username: Ctmike
Ct.
Post Number: 5615
no, unless they are dual 2ohm vc subs instead of svc like you typed. but it's a hifonics, so you wont be seeing 1600w anyways, more like 1400w. set the gain correct then back off it some. but what subs are they?
They are Alpine Type R 2 Ohm(Dual Voice Coil)
Did I type single any where?
Username: •cam•
BC Canada
Post Number: 1393
It's good down to one ohm. You're not going to get exactly 2 ohms, anyway. Speakers are reactive loads, so the impedance (I believe the term resistance is used when it's a resistive load) will change with frequency. Then there's box rise, resistance of your conductors, resistance of terminals, etc. Amps will run cooler at higher impedances.
Username: •cam•
BC Canada
Post Number: 1394
Ohhhh. Then you wire coils in series and subs in parallel. That will give you 2 ohms nom.
I figured I wouldn't get an exact 2 ohm load from the amp, but I didn't see why I should put it down to 1 ohm if 2 ohm would be fine.
Post Number: 8
Sorry about my above post.
So you are now saying that it is possible?
Username: Nd4spd18
Northwest PA
Post Number: 4987
Yes it's possible just do what he said, coils in series on each sub, then both subs in parallel.
Also:
Those hifonics amps are overrated, keep that in mind when setting the gain. That amp at 2 ohm will do ~900 watts at the MOST. Probably closer to 800.
Post Number: 9
Are you serious?
I thought Hifonics was a pretty good brand amp.
If this is true. Would it be better to wire them down to 1 ohm? Would I lose sq or spl? Would the amp get too hot?
Post Number: 10
Username: Nd4spd18
Northwest PA
Post Number: 5004
You can't wire them to 1 ohm if they are dual 2 ohm. You would have to run at 2 ohm and just not be powering the fully, that or get a different amp.
Hifonics are budget quality, and they do about 80% of what the claim for power
Post Number: 11
I knew that Hifonics wasn't top of the line, but I thought they were ok.
I figured $199 for a 1100 watt amp at 2 ohm was pretty good.
I suppose you really do get what you pay for.
Username: Nd4spd18
Northwest PA
Post Number: 5013
They are ok....... they just lie about their power ratings
Post Number: 12
Do they put out on the high side of 80% power or on the low side.
Am I going to be getting around 880 watts or less?
Username: Nd4spd18
Northwest PA
Post Number: 5020
Should be about 800-900
Post Number: 13
Ok. I think I can live with that wattage right now. I'm not looking to compete or anything close to that.
The subs are rated for 500 rms. Am I'm going to notice a big reduction in quality since they are not receiving their full potential?
Username: Nd4spd18
Northwest PA
Post Number: 5022
No. 800-900w compared to 1000w should be barely noticable.
Post Number: 14
Ok. Sounds good. Thanks to everyone for their great advice. .
