Silver Member Username: Ustaad_hc
Post Number: 512 Registered: Oct-06
Posted on hi guys, anybody know about magnum v 3300 fix out yet? Thanks |
Silver Member Username: Runnerguy
Pluto
Post Number: 942 Registered: Sep-06
Posted on Hc Magnum folks can't get a new file out before the the latest has gone bad. I would think that this isn't a good thing. |
Post Number: 513 Registered: Oct-06
Posted on i think so. |
Gold Member Username: Ke5aqn
IF I DONT KNOW THE ANSWER,
I WILL FIND...
Post Number: 2213 Registered: Sep-06
Posted on Not a very good supported box. I would start shopping for a replacement if you want to use a fta receiver to watch DN or BEV. |
Silver Member Username: Space_invader
Andromeda M31
Post Number: 348 Registered: Nov-07
Posted on Magnum coders are very anxious... they don't want to be disturbed...
Pluto
Post Number: 955 Registered: Sep-06
Posted on Only magnums running are one being fed with plastic |
New member Username: Raymgm74
Mccreary,
Manitoba
Post Number: 1 Registered: Dec-05
Posted on hi if this receiver called magnum workes there well be two full moonens |
