Disqec help
Username: Asifali418
Lodi, Ca Usa
Post Number: 102
hi i got dish 500 dp.and i got viewsat brand new disqec switch. i got the both signal 119 and 110 but when i use the disqec switch.its not work.its work on 148 but not 119 and 110 .but when i put it drict from intena its work good.i put 119 on port 1 110 on port 2 and 148 on port 3.some one tell me its disqec switch problem or what but remmebr disqec switch is new one navwer use it
Username: Ke5aqn
Post Number: 2333
The deal is the dish 500 has a Diseqc built in and is made for 2 receivers to use and get both 110 and 119. The the ports out on that lnb are for 2 recivers not 110 and 119.
So if you put a Diseqc switch inline with a dish500 everthing gets confused and it will act JUST LIKE YOUR IS. Your receiver can not control 2 Diseqc switches.
What you need is a DP34 it is the switch designed to add a LNB for another satellite to the dish 500 system.
The way you connect it is like this:
out from the receiver to the DP34, uot the DP34 to dish500 ONCE, out the DP34 to the 61.5 sat's LNB...............thats it
Lodi, Ca Usa
Post Number: 103
but fta tester when i put it drict to reciver its work very good but i need to put 148 too. as a dricet i put only one cable from antena to ricever and its work fine for me buti want 148 too. thx for reply
Lodi, Ca Usa
Post Number: 104
and i want it for only one ricever not for 2 or more
Lodi, Ca Usa
Post Number: 105
i want use one cable from dish 500 and one is from dish 300 .i want dish 500 work for me 110 119 and dish 300 for 148
Username: Ke5aqn
Post Number: 2341
thats fine you still have to use a dp34
you can not use a regular disteq switch with a dish500 or dish pro
in the end it will be 1 coax from receiver to switch, one coax each antenna.
Lodi, Ca Usa
Post Number: 106
what mean dp34.i d,nt know what wrong with my box.
