Basic 101 on inserting Bev keys manually for Pansats etc
Username: Psychmonster
Rhodium MemberAint nuthin ...
Post Number: 329
a lot of people forget to change the Bev provider ID to 0901 (dish is 0101) and as of today the only line u have to enter is the Active which is 00 as of today..
. Press Menu button, then scroll down and Select Parental Controls goto 2nd PIN/enter 0000.
2. Scroll down to Nagravision2 press OK.
3. On the Provider ID BOX, change the provider ID to 0901, then 00 (active for today)
5. Make sure Nagravision 2 on the top left, and KEY NUMBER BOX is 00, scroll down to KEY DATA BOX, enter the new N2 key00.
7. Confirm the N2 key 00 are correct, then press OK to save the new key. Then press EXIT a few times, and you will watching TV right away.
If you Load the Bin that has New N2 Keys update, go to "CAS SYSTEM" menu. You must press "Set default key" Button.
