Bronze Member Username: The_devilPost Number: 79 Registered: Aug-07 | is DN showing or is it only on cricketplus |
Silver Member Username: DizastaUSA Post Number: 104 Registered: Nov-06 | DN is not showing it. |
Silver Member Username: Saqeeb9000Post Number: 977 Registered: Oct-07 | bev is showing it on cbn |
Bronze Member Username: KrishnPost Number: 32 Registered: Sep-06 | It is 730 at 81w correct? Is it possible to add a 5th satellite by having a 22Khz switch to one of the ports of the 4X1 DisEqC switch? |
Silver Member Username: KirankumarNC Post Number: 324 Registered: Oct-07 | Subhash, have you heard of a single dish with a motor? |
Silver Member Username: Saqeeb9000Post Number: 980 Registered: Oct-07 | ""It is 730 at 81w correct? "" posted by subash its 82 west... |
Bronze Member Username: KrishnPost Number: 33 Registered: Sep-06 | Yes,however was trying to get the least expensive solution to the existing set up of 4 orbital locations with dual LNB's, two DisEqC switches to two receivers. |
Silver Member Username: KirankumarNC Post Number: 328 Registered: Oct-07 | is your roof full of dishes?no complaints from neighbours |
Bronze Member Username: The_devilPost Number: 80 Registered: Aug-07 | IS there anyway to get CBN. I have 61.5 and 110 and 119 and is there anyway to swtich to CBN |
Gold Member Username: Saqeeb9000Post Number: 1007 Registered: Oct-07 | YEH... move ur dish to 82 degree west... |
Silver Member Username: Jalaj69Norcross , Georgia USA Post Number: 128 Registered: Sep-06 | yo SADA....which satellite I should move to 110 or 119 to 85 degree west..? |
Gold Member Username: Saqeeb9000Post Number: 1019 Registered: Oct-07 | i don't know...its ur choice...i will suggest 119 b.c it has less ppv's |
Silver Member Username: Jalaj69Norcross , Georgia USA Post Number: 129 Registered: Sep-06 | thanks..... but both will work? |
Gold Member Username: Saqeeb9000Post Number: 1024 Registered: Oct-07 | both meaning? 110 and 82 yes.... |
Silver Member Username: Jalaj69Norcross , Georgia USA Post Number: 130 Registered: Sep-06 | "sada"..sorry i tried but i didn't get the channel.. I think I am doing it wrong--or--did not understand it correctly... Which satellite i should change the degree to...echo 7 or 8.10 to 82 degree.... |
Gold Member Username: Saqeeb9000Post Number: 1032 Registered: Oct-07 | it doesn't matter.,.. u can change any i said 119 (b.c it has less ppv's ),/// ok now when are u changing it.. u will see sat 82 on top...of instalation menu..change the sat name to nimq2 or *82 west..and u will see on top..it should says nimq2...then u can scan the channel.. |
Silver Member Username: Jalaj69Norcross , Georgia USA Post Number: 132 Registered: Sep-06 | hey i did find the "nimq2" satellite that was at 82 degree, but everytime i try to blind scan it keeps on freezzzzing on me and shuting off!!! n e idea why? |
Gold Member Username: Saqeeb9000Post Number: 1037 Registered: Oct-07 | why are u doing blindscan..just do a normal scan...cbn is always available.. if not do a mannual scan... check my forum forum for cricket lover's for frequ,etc for cbn channel... by the way what rec do u have.. |
Silver Member Username: Jalaj69Norcross , Georgia USA Post Number: 133 Registered: Sep-06 | pansat 2700a clone!! |
Gold Member Username: Saqeeb9000Post Number: 1038 Registered: Oct-07 | so did normal scan worked......... |
Silver Member Username: Jalaj69Norcross , Georgia USA Post Number: 134 Registered: Sep-06 | aaaa no it keeps on freeezzzing on me... I selected "nimiq2/ku" i am not sure if this what you ment!! but i don't see any satellite that says "nimq2"... I did LNB: standard LNB: 11250 22khz: on DiSEqC: #4 Legacy SW: None Skew: .45 TP:[19] 12486 v 20.000 Positioner Setting: Disable Only option i have is to scan ALL.... I dont have normal scan option..!!! AM I DOING N E thing wrong? |
Gold Member Username: Saqeeb9000Post Number: 1039 Registered: Oct-07 | may be turn off 22khz |
Silver Member Username: Jalaj69Norcross , Georgia USA Post Number: 135 Registered: Sep-06 | k..i guess let me try!! but think it didn't work b 4 but all the setting was different too.... if you think of anything else please LMK... THANKS |
Gold Member Username: Saqeeb9000Post Number: 1041 Registered: Oct-07 | DiSEqC: #4 thats where your 82 dish is right now.. how many dishes do you have.. |
Silver Member Username: Jalaj69Norcross , Georgia USA Post Number: 136 Registered: Sep-06 | 3...ECHO 3, 7, 8.10 |
Bronze Member Username: The_devilPost Number: 81 Registered: Aug-07 | Does anyone know why there not showing it on DN |
Silver Member Username: Pannu16Post Number: 715 Registered: May-06 | Jaklaj i guess u got FLU!! Thats has got lil problem while scanning, i have seen it before!! Change satelite on ur settings, leave diseqc as one on nimiq 2 and do blind scan!! |
Bronze Member Username: The_devilPost Number: 82 Registered: Aug-07 | list of channels that are showing the match http://www.itsonlycricket.com/entry/603/ |
Silver Member Username: Jalaj69Norcross , Georgia USA Post Number: 137 Registered: Sep-06 | PANNU; I tried to do the blind scan and the TP scan but SH$T still not working... I cant get that "CBN" channel....> I dont know what to do... |
Silver Member Username: Pannu16Post Number: 718 Registered: May-06 | well its hard to say if u r pointing at right bird!! So do u get any channel on blind scan!! If yes then wat!"! If no then u r not lookin at right bird!! U gotta do a blind scan but on right bird though!! |
Bronze Member Username: The_devilPost Number: 83 Registered: Aug-07 | what channel is CBN on BEV |
Bronze Member Username: BombermanPost Number: 93 Registered: Sep-07 | pannu stop giving stupid advice to people, you can't fix ur own receiver( your friend has to do it for you) how are you going to help someone else???? jalaj, from installation menu select nimiq 2, make sure your settings are correct, then if you see a good signal and quality, that means you're ready to scan.. Freezing on fortec is common with these new crappy bins, i don't know what the reason is, so if it's freezing for normal scan, try doing a tp scan for some channel and then it will scan easily for others. if you still can't get it to work, best thing is to load a channel list for nimiq 2 hahahaha |
Gold Member Username: Saqeeb9000Post Number: 1058 Registered: Oct-07 | jack smith it 703 channel called cbn... |
Silver Member Username: Jalaj69Norcross , Georgia USA Post Number: 138 Registered: Sep-06 | Man I am getting all the channels in NIMIQ 2 except CBN.. I have good signal LNB: standard LNB: 11250 22khz: OFF DiSEqC: #4--AND TRIED #1 Legacy SW: None Skew: .45 TP:[19] 12486 v 20.000 Positioner Setting: Disable |
Bronze Member Username: BombermanPost Number: 99 Registered: Sep-07 | do tp scan tp 4, 12268 L |
Bronze Member Username: ShitabattiePost Number: 29 Registered: Dec-07 | Can some one confirm that the game is showing on CBN |
Bronze Member Username: The_devilPost Number: 86 Registered: Aug-07 | http://www.itsonlycricket.com/entry/603/ this will confirm that CBN is showing the series |
New member Username: Klondike_kikePost Number: 8 Registered: Dec-07 | |
Bronze Member Username: SanwadhPost Number: 17 Registered: Oct-06 | I am getting signal is weak on most of bev channels, anyone can help me?? |
