Bronze Member Username: Rellikfl
New Port Richey,
FL
Post Number: 35 Registered: Dec-07
Posted on Anyone have experience with either? They both put out about the same RMS @ 1ohm and both cost about the same. Which is better? |
New Port Richey,
FL
Post Number: 40 Registered: Dec-07
Posted on even tho the AQ isnt out yet. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 4892 Registered: Jul-06
Posted on AQ It is supposed to be similar to DD amps in quality, and in that case it will own |
Gold Member Username: Juliob
Santo DomingoDominican Re...
Post Number: 5081 Registered: Dec-05
Posted on get the cheapest one |
Silver Member Username: Hurricanebr1an
Western Burbs of Chicago,
IL
Usa
Post Number: 305 Registered: Sep-07
Posted on AQ |
Gold Member Username: cam
BC
Post Number: 1368 Registered: Nov-06
Posted on "get the cheapest one" X2. You'll be happy either way, so spend the least amount of $$$ you can. |
New Port Richey,
FL
Post Number: 68 Registered: Dec-07
Posted on Just ordered the AQ. Cant wait to hook it up to the 12's |
