New member Username: Freebird1963Post Number: 6 Registered: Dec-07 | [somehow I dumbed up and posted this in the wrong forum originally. sorry about that] Hello I did the conversion like Nalin sent me. (I hope I spelled the name right - sorry if I didn't). Seems to have been taken properly. System info shows Safe 75-231T_EUbX 22 Dec 2007 I can do a power scan and get channels but all the channels say BAD OR SCRAMBLED CHANNEL. My quality and signal level is in 89-92 range. I have shutdown seveal times. Pulled power cord. Tried entering keys manually. This is a Multistar Pantec Ultra that was converted to the 2500-2700 files. What did I miss or do wrong possibly. THanks for the help F-Bird |
Silver Member Username: Jagr1234Post Number: 125 Registered: Nov-07 | reset default key and let them roll...that may work |
Silver Member Username: Jagr1234Post Number: 126 Registered: Nov-07 | not sure bad scrambled chan usually isnt keys.....also are you sure that bin is for converted box....you should use jvvh 231 . i used the one in the fortec files on ftabinbins....not much freezing. |
Silver Member Username: ViruscauserLeesburg, Georgia Post Number: 637 Registered: Mar-07 | The 232 bin for the converted receiver is already out and you should use that one. Load that one, do a default setting, reenter your correct antenna settings and do a power scan on each of you Sats. Then set Default keys, exit out, go to channel 200 (CNN) and wait for keys to roll. That should work. |
Gold Member Username: NydasPost Number: 6470 Registered: Jun-06 | For Pansat 2500/FLU new conversions and converted to 2700 In case you have difficulty getting the latest BIN, it is available here. Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. The latest jvvh_232_(BG)_ bins included and available separately The latest CS_232T_lightning Bin included and available separately. http://public.box.net/2500_full_kit FOR DN and BEV FIX 24th December, 2007. Please follow the instructions precisely including instructions after the upload of the BIN. |
New member Username: Freebird1963Post Number: 7 Registered: Dec-07 | Thanks guys. I d/l the 232 but then my remote wouldn't work. Sat at the language screen. I have already loaded the conversion bins/boot. after doing the 232 upload I had to go back to the conversion kit. I uploaded the maple leaf one and now have some of the regualar channels but no premier ones. Anything special needed to be done when uploading the 232 bin ? Thanks again for the help. F-Bird |
Gold Member Username: NydasPost Number: 6483 Registered: Jun-06 | The files posted at http://public.box.net/2500_full_kit work well. Please follow the instructions regarding Default setting, TV setup etc containe din detail in the Instructions with the KIt. |
New member Username: Freebird1963Post Number: 8 Registered: Dec-07 | Nalin, Thanks that did it. the 232 did it. I didn't realzie that there were different files in this kit. GOt my epg and all channels back. Not sure if its me or not but the pic even looks better. Thanks to all that helped out. Merry Christmas Nadia you must be one lonely person or are you a stalker that can't have nalin ? sure do take pot shots at the person while offering nothing useful yet. So please keep out of my discussions were those that came to help tried and were you offered nothing but ignorance. |
