I was smart enough to buy the vs ultra with a usb port, however my friend didn't. He needs to know how to install the new bin through a serial cable. Any help would be great.
If it came with the receiver, it's probably the correct cable.
Here is the procedure: Viewsat 2000 Ultra Setup Guide Using Serial Cable (NULL)/USB
A. Loading your BIN using Null cable:
Connect serial cable (NULL) to PC>STB Open up Loader of choice (PVR-Loader 1.1 or Loader2) Click on Tool>Configuration>Com port (Default is com 1) Click on Open File Click on PC>STB (Notice the progression bar in loader) Turn the power in the back ON Wait for Loader say Completed. Then on box LCD front panel screen say I.N.S.T>END>0000 or until clock count to 0.001 IT IS VERRY IMPORTANT. DO NOT TURN THE POWER OFF TO SOON Turn the power OFF in front and power OFF in back After downloading the "BIN", unhook NULL cable from PC>STB Connect all the cables to your box/TV Turn the power ON in the front and back Press Menu key Select Installation and press OK Select Antenna Setup and press OK Select your Sat. Here if you have a DISEqC switch enter the port #, Motor or Legacy SW No LNB Type need to select (from new, you have only two selection Standard and Universal). STB will select your LNB Automatic Press Exit and select Yes for saving the settings Your back to Antenna Setup screen Here you have Three choices: 1. Channel Scan 2. Auto Scan 3. Blind Scan Select Auto Scan Press OK You are in the Auto Scan window and you see the Bird(Sat.) you selected and on the top of your screen are three options: 1. Search option 2. Network search 3. Scan Start You don't change nothing here, go down and select Scan Start and press OK You do this for all the Birds (Sat.) you have Wait for Autoroll and watch TV
B. Loading your BIN using USB Jump Drive
Now its time to download your BIN Insert the Memory Stick in your PC and transfer the bin in. Then insert in your STB and in the Main Menu select System information and press OK Select Receiver Upgrade and press OK Go down to the bottom of the window, select USB and press OK A new window opens with some Korean files, years, etc. In the bottom of the window, it is your bin selects and presses OK VERY IMPORTANT. DO NOT TURN THE POWER OFF Press Menu key Select Installation and press OK Select Antenna Setup and press OK Select your Sat. Here if you have a DISEqC switch enter the port #, Motor or Legacy SW No LNB Type need to select (from new, you have only two selection Standard and Universal). STB will select your LNB Automatic Press Exit and select Yes for saving the settings Your back to Antenna Setup screen Here you have Three choices: 1. Channel Scan 2. Auto Scan 3. Blind Scan Select Auto Scan Press OK You are in the Auto Scan window and you see the Bird(Sat.) you selected and on the top of your screen are three options: 1. Search option 2. Network search 3. Scan Start You don't change nothing, go down and select Scan Start and press OK You do this for all the Birds (Sat.) you have Wait for Autoroll and watch TV
