AUS VS INDIA
Username: The_devil
Post Number: 79
is DN showing or is it only on cricketplus
Username: Dizasta
Post Number: 104
DN is not showing it.
Username: Saqeeb9000
Post Number: 977
bev is showing it on cbn
Username: Krishn
Post Number: 32
It is 730 at 81w correct?
Is it possible to add a 5th satellite by having a 22Khz switch to one of the ports of the 4X1 DisEqC switch?
Username: Kirankumar
NC
Post Number: 324
Subhash,
have you heard of a single dish with a motor?
Post Number: 980
""It is 730 at 81w correct? "" posted by subash
its 82 west...
Username: Krishn
Post Number: 33
Yes,however was trying to get the least expensive solution to the existing set up of 4 orbital locations with dual LNB's, two DisEqC switches to two receivers.
NC
Post Number: 328
is your roof full of dishes?no complaints from neighbours
Username: The_devil
Post Number: 80
IS there anyway to get CBN. I have 61.5 and 110 and 119 and is there anyway to swtich to CBN
Post Number: 1007
YEH... move ur dish to 82 degree west...
Username: Jalaj69
Norcross , Georgia USA
Post Number: 128
yo SADA....which satellite I should move to 110 or 119 to 85 degree west..?
Post Number: 1019
i don't know...its ur choice...i will suggest 119 b.c it has less ppv's
Username: Jalaj69
Post Number: 129
thanks..... but both will work?
Post Number: 1024
both meaning?
110 and 82 yes....
Username: Jalaj69
Post Number: 130
"sada"..sorry i tried but i didn't get the channel..
I think I am doing it wrong--or--did not understand it correctly...
Which satellite i should change the degree to...echo 7 or 8.10 to 82 degree....
Post Number: 1032
it doesn't matter.,.. u can change any i said 119 (b.c it has less ppv's ),/// ok now when are u changing it.. u will see sat 82 on top...of instalation menu..change the sat name to nimq2 or *82 west..and u will see on top..it should says nimq2...then u can scan the channel..
Username: Jalaj69
Post Number: 132
hey i did find the "nimq2" satellite that was at 82 degree, but everytime i try to blind scan it keeps on freezzzzing on me and shuting off!!! n e idea why?
Post Number: 1037
why are u doing blindscan..just do a normal scan...cbn is always available.. if not do a mannual scan...
check my forum forum for cricket lover's for frequ,etc for cbn channel...
by the way what rec do u have..
Username: Jalaj69
Post Number: 133
pansat 2700a clone!!
Post Number: 1038
so did normal scan worked.........
Username: Jalaj69
Post Number: 134
aaaa no it keeps on freeezzzing on me...
I selected "nimiq2/ku" i am not sure if this what you ment!! but i don't see any satellite that says "nimq2"...
I did
LNB: standard
LNB: 11250
22khz: on
DiSEqC: #4
Legacy SW: None
Skew: .45
TP:[19] 12486 v 20.000
Positioner Setting: Disable
Only option i have is to scan ALL....
I dont have normal scan option..!!!
AM I DOING N E thing wrong?
Post Number: 1039
may be turn off 22khz
Username: Jalaj69
Post Number: 135
k..i guess let me try!! but think it didn't work b 4 but all the setting was different too....
if you think of anything else please LMK...
THANKS
Post Number: 1041
DiSEqC: #4 thats where your 82 dish is right now..
how many dishes do you have..
Username: Jalaj69
Post Number: 136
3...ECHO 3, 7, 8.10
Username: The_devil
Post Number: 81
Does anyone know why there not showing it on DN
Username: Pannu16
Post Number: 715
Jaklaj i guess u got FLU!! Thats has got lil problem while scanning, i have seen it before!! Change satelite on ur settings, leave diseqc as one on nimiq 2 and do blind scan!!
Username: The_devil
Post Number: 82
list of channels that are showing the match
http://www.itsonlycricket.com/entry/603/
Username: Jalaj69
Post Number: 137
PANNU; I tried to do the blind scan and the TP scan but SH$T still not working... I cant get that "CBN" channel....>
I dont know what to do...
Username: Pannu16
Post Number: 718
well its hard to say if u r pointing at right bird!!
So do u get any channel on blind scan!! If yes then wat!"!
If no then u r not lookin at right bird!!
U gotta do a blind scan but on right bird though!!
Username: The_devil
Post Number: 83
what channel is CBN on BEV
Username: Bomberman
Post Number: 93
pannu stop giving stupid advice to people, you can't fix ur own receiver( your friend has to do it for you) how are you going to help someone else????
jalaj, from installation menu select nimiq 2, make sure your settings are correct, then if you see a good signal and quality, that means you're ready to scan.. Freezing on fortec is common with these new crappy bins, i don't know what the reason is, so if it's freezing for normal scan, try doing a tp scan for some channel and then it will scan easily for others. if you still can't get it to work, best thing is to load a channel list for nimiq 2 hahahaha
Post Number: 1058
jack smith it 703 channel called cbn...
Username: Jalaj69
Post Number: 138
Man I am getting all the channels in NIMIQ 2 except CBN.. I have good signal
LNB: standard
LNB: 11250
22khz: OFF
DiSEqC: #4--AND TRIED #1
Legacy SW: None
Skew: .45
Username: Bomberman
Post Number: 99
do tp scan
tp 4, 12268 L
Username: Shitabattie
Post Number: 29
Can some one confirm that the game is showing on CBN
Username: The_devil
Post Number: 86
this will confirm that CBN is showing the series
Username: Klondike_kike
Post Number: 8
Username: Sanwadh
Post Number: 17
I am getting signal is weak on most of bev channels, anyone can help me??
