Second batt ?
Username: Snarl2004
Digital Design 9515, Massive Audi...
Post Number: 1999
im trying to install my HC2400 and i dont have enough 1/0awg for everthing. i was wondering if it is alright if i ground the HC2400 with 4awg for a couple of weeks then when i get the money switch to 1/0awg. ill be using a P3000.1 on it if it matters (about 2800rms)
Username: Carguy
Post Number: 6925
You can either wait or double up on 4ga wire if you have enough.
Username: Nd4spd18
Northwest PA
Post Number: 4880
Yeah, you could use two 4 gauge wires. Don't try to do it with just one.
