One jl 12"w7 vs two jl 12"w6v2??
Username: Ahodk
they cost not much different~ but in the sound...which will perform better???and which amp to go with it is better???
Username: Markd
UK
Post Number: 8
i think that 2w6's would definitely go louder than one w7, as long as you had enough power to drive them. as far as sound quality goes, i couldn't tell you. i guess the w7 would sound better, but 2w6's wouldn't exactly sound bad!
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 3264
500/1 for a 12W7
1000/1 for two 12W6v2s
