Ok my friend wants to hook up 3 subs. THe only way i could think of doing it with 1 amplifier would be to do it in series since you cannot wire 3 subs parrallel. running it in series would you double or trible the ohm load? if they are all svc 4 ohm waht would that end up being. what if they are dvc 4 ohm. if im not understanding this right please help because im thinking that you couldnt get a low ohm load which would mean you would get very little output from your amp at a high ohm load.
