Speakers/Amplifier for Pioneer PD-F1009
Username: Nontech
Westerly, RI USA
Can anyone help?
I just received a Pioneer PD-F1009 for Christmas and I have no idea which speakers or amplifiers
are compatible with it. Do I need both? My last set is about 25years old and it came all together, in one box. I'm really kind-of
"lost"!
Thanks!
Username: Wattsssup
Barrie, ON Canada
Post Number: 160
Hi Mary,
It looks like you got yourself a cd player for xmas. Congrats.
You will need to use either an amplifier (pre & amp or "integrated") or a receiver. You will also need speakers.
Since you will need to invest some money into your new system, a bit more info from you, will help generate better responses from other members here.
Do you want to only use for music? Would you like the option for surround sound for movies?
Username: Nontech
Westerly, RI USA
Hi Marc,
Thanks! Your response helped a lot. I'll most likely be using the CD player just for music. Now I'll have some idea of what I should be looking for when I go shopping.
Mary
