Silver Member Username: Book77Post Number: 114 Registered: May-06 | Anyone having freezing problems |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 2300 Registered: Sep-06 | Spend some time ( 5 min ) reading the forum and you would see everyone is having trouble at this time. We all have to wait for new bin's. Some are having some luck SLOWING the freezing down by doing little "tricks" but all receivers need new bins. If your bored spend some time watching a free movie or tv show here! http://www.ovguide.com/ |
Silver Member Username: Pathfinder191Post Number: 285 Registered: Mar-06 | Nalin or The FTA Taster: I saw some files called SonicView Softkey. What does it do? Thanks. |
Gold Member Username: NydasPost Number: 6489 Registered: Jun-06 | Softkey maker 2.03 for Sonicview generates a .key file of the current keys. With autoroll working, it is not needed, and I have never used it. The only new thing about it would be if it was a new softkey maker for 0106 or 0907 ID and could generae keys which would integrate well and work without loading a BIN. This is a tall order. |
