Loading bins to CaptiveWorks CW-600S
Username: Snissar
Post Number: 21
hey guys
this is the first time i am a loading bin to captiveworks 600s .
I have the lastest factory software its 2.50 and i want to add the latest software (bin) so i have the loader 1.5
when i load the new bin CW600SV1.57, the options Download S/W is selected and COM1.
when i click it start the progress bar remains to zero
whats the problem plz help.
Username: Snissar
Post Number: 23
h3elppppppppp
Username: Ke5aqn
Post Number: 2354
try to reboot the host computer it helps most of the time with that error...let me know
Username: Snissar
Post Number: 24
i shut down my pc and back on it doesnt trnasfer the bin
Username: Dimwitt
Post Number: 317
are you putting the cw600s into standby mode --:--
and using null cable .
Username: Snissar
Post Number: 25
no i turn it off and then hold the power button
for boot mode
Username: Snissar
Post Number: 26
plz trying if from last night :-(
Username: Snissar
Post Number: 27
i cant fix it i dont know what s the reason
i have RS 232 cable my CW is kround 2.50 factory bin
when i want to load new bin with 1.05 loader it remain to zero:-(
Username: Brucester
Post Number: 885
how to set up for captive work 600s
copied from an other site credit goes to Mrokarvi. this is what i used to set mine up withCaptiveWorks CW600s Guide by Mrokarvi
CaptiveWorks 600S Guide
Created by Mrokarvi
Credit goes to Mr.CaptiveWorks and all others who posted information on the web; I just put together in this little guide to help newbies.
Also available in pdf in downloads section CW600s Guide
1.How to update s/w by PC?
1) Prepare a twisted RS232C cable(pin-2 to pin-3,pin-3 to pin-2,pin-5 to pin-5) or You can buy a null modem cable available at most electronic stores.
2) Connect your PC and receiver with twisted RS-232C Null modem cable.
3) Turn on the receiver you will see 00:00 and then press "POWER" key on front of the receiver panel to make it standby, the LED dot - - : - - will blink.
Note: Loader will not work until you see - - : - - on LED panel
4) Run the LoaderV1.02/LoaderV1.04 on your PC. Select the right COM port where you connected your null modem cable usually COM1, then select
<download>,press <open> and select the bin file, then click <start>, upgrade will begin.
5) After finishing, the LED will display "-End"
2.How to Enable Patch or Disable Patch?
Exit all menu, Press F1 key, the LED will display 'H', then press '000'
3.How to Edit Patch key?
After Enable patch key, go to Main Menu-->Installation-->Patch Menu
4.How to Select EPG style?
From main menu >system setting->system->EPG style can change
Normal: Viewsat/C00lsat/Pansat style
Scroll Txt: Old Captivework style
5.How to configrure the SID sort?
From main menu->system setting->system->channel No. style can change:
Normal: Normal sort order
SID sort: Dish order
6.How to Category Search?
(Available only in V1.41)
1) Make sure the epg is loaded- to do that just open the epg screen and see if the boxes are full, if not go choose any box that has no epg and wait 15-20 sec and it will be filled. ( you only need to do this once in the beggining).
2) Then exit and hit F2 on your remote.
3) Category box will open, just choose what category you want to watch and hit ok
4) After 2-3 seconds, a list of channels will open which are CURRENTLY playing these categories (every half hour this list changes when a new show is finished or started)
5) Next to the channel there is the title of the show, if you hit INFO button it will open the full information, hit INFO again and it will disappear. Just select what you like and watch.
7.How to Blind scan? (Available only in V1.42)
BLIND SCAN function can be accessed by going to
From main menu-> Installation -> selecting the satellite that you want blind scan and press F1 key on your remote.
8.How to Clone CW600s Box to Box?
From DigitalPlus:
1) Connect the master and slave box with twist RS232 null modem cable (pin2 to pin3, pin3 to pin2, pin5 to pin5).
2) Start the master receiver and press "POWER" key to make it standby "- - : - -".
3) Start the slave receiver, in the master box the led will display 'H' and blink it.
4) Input the password:
111 ---- Transfer S/W
222 ---- Transfer data
333 ---- Transfer data, then S/W
444 ---- Copy whole flash except Boot Loader.
5) After finishing inputting the password. Transfer will begin. When it finish, the LED will Display "-End". Disconnect the cable, start your receiver.
Note: By the different password, you can do what ever you want to do for Box to Box.
9.How to set DishPro LNBs?
(Available only in V1.43)
DishPro LNB settings can be accessed by going to
Main Manu-> Installation-> Antenna Setting-> 5th Option LNB type
10.How to Set Legacy SW21/42/44/ Switch?
Legacy Switches settings can be accessed by going to
Main Manu-> Installation-> Antenna Settings->4th Option Legacy SW
Set the type of switch you got on your dish setup. Don't forget to set DISCQ setting to none otherwise it will not work properly.
11.How to set channel lock on certain channels?
Channels can be locked by going to
Main Manu->Channels Manager->channels Edit ->go to that specific channel you want to put lock on and press blue key on your remote.
Username: Snissar
Post Number: 28
that doesnt work
cuz loader 1.05 is already out
that guide before the kround
Username: Yovanibot
Post Number: 12
YOu must have the receiver on stand by to load it. Press the on and off button for a second and you will get the >> --:--
Username: Yovanibot
Post Number: 13
Don't forget to activate the patch after you plug in receiver to the TV.
