Port Diameter?
Username: Rellikfl
New Port Richey, FL USA
Post Number: 70
If I want to make a box thats 4.5cf and tunned at 33hz, whats a good port diameter?
Username: Insearchofbass
Post Number: 7442
digital deigns would say 14 square inches per cubic feet so 63 square inches of port but you dont have to use that much if you dont have the room for it
Post Number: 7443
bump
Username: Rovin
4 10 Pioneer...
Post Number: 12648
depends on the sub but IMO i found 12sq"\cuft = a nice allrounded sql......
Username: Rellikfl
Post Number: 75
I contacted SI about the BM Specs and there reply was:
"For the BM 12" drivers, aim for 2 cubic feet tuned to 34 Hz (per driver). Each driver displaces 0.1 cubic feet, and be sure to account for your port displacement (port surface area per driver should be near 20-24 in^2)."
So I'm Thinking a 4cd box tunned at 34Hz with dual center ports(ports 22in^2 a piece) would be ideal?
What do you guys think?
Username: Rellikfl
Post Number: 76
^4cf*
