Username: Rellikfl New Port Richey,
FL
Post Number: 15 Registered: Dec-07
Saturday, December 22, 2007 - 00:52 GMT What has a better sound quality/loud ratio? 2 12's or 1 15"?
Username: cam BC
Post Number: 1361 Registered: Nov-06
Saturday, December 22, 2007 - 00:55 GMT Depends on subs/box.
Username: Loudon Post Number: 2114 Registered: Jun-04
Saturday, December 22, 2007 - 00:55 GMT onces again ideally most people will say that 2 12s power and enclosed properly will be louder due to the amount of surface area being large then that of a 15 inch woofer, but it also depends on the subs been compared for instance a pair of kicker cvr 12's aren't going to be louder then a fi btl ... specify what ur looking for... itll make it alot easier to help you out bud
FL
Post Number: 17 Registered: Dec-07
Saturday, December 22, 2007 - 00:55 GMT Im looking for a clean yet loud sound btw.
FL
Post Number: 18 Registered: Dec-07
Saturday, December 22, 2007 - 00:57 GMT I dont know as far as brands. Im just looking for a good quality clear sound that is loud. Which of the two would be better for that?
Username: cam BC
Post Number: 1362 Registered: Nov-06
Saturday, December 22, 2007 - 00:58 GMT /vehicle.
Username: Loudon Post Number: 2116 Registered: Jun-04
Saturday, December 22, 2007 - 01:01 GMT well it says in ur profile u have a Ford Taurus, which has a huge trunk in it depending on ur subs an ideal tuning would be somewhere around the 32hz range ... which makes the woofer able to excel at different types of music. sealed well youd have to make the box the size that company recommends for their woofers
FL
Post Number: 21 Registered: Dec-07
Saturday, December 22, 2007 - 01:01 GMT ford taurus
Username: Nd4spd18 Northwest PA
Post Number: 4760 Registered: Jul-06
Saturday, December 22, 2007 - 01:14 GMT 2 12s > 1 15" on the same power
FL
Post Number: 24 Registered: Dec-07
Saturday, December 22, 2007 - 01:15 GMT Thanks M.S.
Username: Jkidder Gunshine ,
State
Flawda
Post Number: 2950 Registered: Nov-05
Saturday, December 22, 2007 - 21:44 GMT what year?
Username: Tips Post Number: 223 Registered: Jan-05
Saturday, December 22, 2007 - 22:02 GMT wouldn't it also depend on they type of music you listen to? if you only listen to rap music. wouldnt a 15 be able to hit the notes lower than 2 12s?
Username: Gh0st_31 USF,
FL
Post Number: 644 Registered: May-06
Saturday, December 22, 2007 - 22:29 GMT 2 12s would be louder in a properly made box but I always like single sub setups more. only 2 more db louder for twice the price. plus i like to look of just 1
Post Number: 4804 Registered: Jul-06
Saturday, December 22, 2007 - 22:40 GMT That's a myth......... 2 12"s should be louder than 1 15" even on the low end.
Username: Frkkevin Resonant Engineering...,
Fort Worth...
Email
Post Number: 4360 Registered: Nov-05
Saturday, December 22, 2007 - 22:43 GMT all depends on a lot of variables.. sound displacement for 2 12s is not a whole lotter greater than 1 15
Username: Cblaze Rock island,
Tenesssee
Us
Post Number: 987 Registered: Sep-07
Sunday, December 23, 2007 - 01:44 GMT not much diff,i would just go with what you want
