OK, I know that 239 loads DN epg in 3 minutes.......?
Username: Fredfarmer
Post Number: 61
What channel loads BEV epg please??
Yes I know how to load the EPG, but some members of my family refuse to learn??
Turning to 239 loads the epg faster then going to menu, epg etc, and its easy.
There must be a channel on Bev that does the same...what channel is it please??? Anybody know?
Username: Ke5aqn
Post Number: 2223
What is your receiver ? EpG works a little diferant with some receivers..
Post Number: 63
Yes I know turning to channel 239 for 2-3 minutes loads DN epg...but it does not load Bev...What is the channel to turn to to load bev??
Post Number: 65
Viewsat Plat...thanks
Username: Dimwitt
Post Number: 303
EPG , 91W ,TP 12311, CH#280
EPG , 82W ,TP 12224 CH#260
Post Number: 66
VS PLAT thanks
Username: Ez2ctv
Platinum Mem...
Post Number: 23
B3V Ch 510 for 2 - 3 minutes
DN 239 for 10 - 15 minutes Then 310 for 5
Post Number: 67
Thanks to all that responded, I set it at 280 or in my case 2280 and it loaded bev in 2 minutes. 239 loads my DN in 3 minutes.
great thanks.
Username: Ke5aqn
Post Number: 2228
I have a question for you. I also have a plat here. I have NEVER had a EPG worth a darn..
I can never get more than 2-6 hours worth of a guide at a time. I get BEV guide about the same from any channel I go to but never for more than 2-4 hours and the EPG is lost when I go to like g10 a FTA sat so i have to back to a DN sat to get the guide back. I have done all that channel 200 on DN and also tried downloading the EPG from the munu as well with same 2 hour guide..
I do have 17 sat's and 24000 channels scanned so I am at like 65% of memory taken up with channel data mabee thats why I cant keep or realy receive a good EPG....whats your thoughts on this EPG problem?
I end up using tvguide.com LoL
