before you updat the keys 0901 turn first your autoroll off , then updat manually the keys . you will get back your bev , but remember to turn on again your autoroll after updating .enjoyyyyyyy
^ yes But I was Wondering that Since I changed my BEV 08 01 00 key It might be causing the issue Now ....
VS Pro don't Allow Op Key Updates so have to do al entries manually. I will keep checking for any small Mistakes. I think I followed all the steps. Switched of Auto Rool for BEv. Double Checked the BEV 09 01 00 keys. Saved then but still I am getting AutoRoll banner. Even rebooted the Receiver. Will See if I make any progress on that
