Bronze Member Username: Kingofdakingz
Post Number: 76 Registered: Jun-06
Posted on NEW FILES OF VIEWSAT ULTRA CONFIRMED AND POSTED BY ADMIN ON FTATALK. COM |
Post Number: 78 Registered: Jun-06
Posted on [link removed] HERE IS THE LINK |
New member Username: Jabberosx
Post Number: 10 Registered: Oct-07
Posted on Yep can verify.. Admin at ftatalk.com posted the Viewsat Ultra fix.. ================================= Release VS XTREME ULTRA Note ================================= ------------------------------ PFTAUSW-071222U ------------------------------ * Versions - Release Date : 2007.12.22 - Main software : PFTAUSW-071222U - Boot Ver : 0.10 * Change (Main software upgrade) - AR Update |
Bronze Member Username: Jabberosx
Post Number: 11 Registered: Oct-07
Posted on Only trust Ftatalk.com and totalFta.com.. Testing the file now.. will be back in a min to confirm. |
Bronze Member Username: Dharm_ram
Post Number: 58 Registered: Dec-07
Posted on has anyone tried it? |
Bronze Member Username: Hemi426no1
Post Number: 21 Registered: Sep-06
Posted on it freezes up every few minutes |
Silver Member Username: Leafs
Post Number: 227 Registered: Oct-07
Posted on new viewsat fixes posted at www.ftasolutions.blogspot.com |
Post Number: 12 Registered: Oct-07
Posted on It worked. But it is freezing. And the system needs to be reset to start again. |
Post Number: 79 Registered: Jun-06
Posted on NO FREEZING FOR ME I LOADED THE BIN FILE 2 TIMES AND ITS GOOD TO GO |
