Hi Guys, I am planning on buying a new FTA Receiver. What receiver is the best out there now for a reasonable price (under $200) that has great support(releases the fixes in no time, doesn't let the customers down) Need some opinions. Thanks.
the best bang for the doller is captive works cw600p under a 100 canadian and got great support and eazy to us all you do is buy it load bin hit f1 000 on remote and watch tv
Nfusion - never down on IKS requires internet to be plugged in it Viewsat Ultra - great box usb update fixes usually fast Viewsat HD - great for HD same as ultra PVR capable Captive Works 600P - cheap fast fixes and costs around 70-90$ Sonicview 4000 - same as ultra
these are what i think should be a list to chose from...others usually will be longer to get fixed and you will not enjoy as much as the above ones
