New system
Username: Kingtutus
Lincoln, Nebraska U.s.a
Post Number: 41
i am looking in to getting 2 fi 18 q's but i need a new hu and a good amp. im think about getting jk atomic 5k is that a good idea.
Username: Kingtutus
Post Number: 42
jk32sho's atomic
Username: Kingandsons07
Lincoln, Nebraska U.S.A
Post Number: 435
do it man but don't turn the gain up to much and you will be so happy with it
Username: Jakeyplaysbass
ASU
Post Number: 2231
do you have the charging system to run that much power?
250-300amp alternator
2+ batteries
big 3 upgrade to 1/0 wire
just know what your getting into before you decided to go big.
Post Number: 436
he dose i'm helpin puttin stuff in his truck
Username: Philly306
North carolina
Post Number: 688
you are gonna need alot of space for 2 18" Qs
Post Number: 438
i'm thinking of 13-15 cuft 30Hz your going to be bangin
Username: Buccaneersfan80
im looking into purchasing my first new system for my car and im stuck between what subs i should get as well as an amp, im looking at two 12 MTX Thunder 4500s or two 12 Alpine SWE-1242? and as far as amps ive been told alot of different things so im kinda confused if anyone has good advice for which of those subs are a better choice and whether or not a shouuld buy a kicker mono amp or an alpine mono amp id really appreciate it
Username: Kingtutus
Post Number: 43
if i was you i have heard both of them and i would go with the alpines they can handle more power then the mtx, the mtx will blow really easy if you have anything setup wrong.
Username: Vtouch06
Q-TowN, PA
Post Number: 280
def dnt get MTX subs if you get alpine, get the type R's and get a kicker amp they give u the bang for your bucks and there under-rated..they usually do more rms.., usually there's good prices on ebay for them...
thanks guyz, what kind of enclosure would you reccomend i know both ported and sealed have their own pros but if i wanted it to bring out the most bass possible would i go with a ported?
Username: Drant19
DUB-C, TX
Post Number: 141
ported definately!
thanks, i found this deal on crutchfield
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=208250&i=700ALPPKG6&tp=4 42
would you guys look into this or build another piece by piece on ebay, because ive heard the type e alpines arent as good so ive been looking at the type Rs like V.T. said. i also had a question what is the difference between 4ohm and 2ohm subs
Username: Fred_sanford
Huntsville, Alabama Usa
Post Number: 73
their are better deals to be had, what budget and what kind of car do you have
i have a 2000 nissan Pathfinder, and i'm looking to spend about 300 on subs or a little more inculding the enclosure
Username: Vtouch06
Q-TowN, PA
Post Number: 287
the difference between 4ohm and 2ohms is what you wire them too, and what amp you are using...heres the wiring options...
(2)Dual 2 ohms wired in parallel/series=2ohm load
(2)Dual 4 ohms wired in parallel/parallel= 1ohm load
and then just find amp that is 2ohm or 1ohm stable your choice....
I found this on ebay (2) Dual 4 ohms for $234.45 shipped...then you would need an 1ohm stable amp
http://cgi.ebay.com/2-ALPINE-SWR-1242D-12-3000W-PAIR-SUBWOOFERS-TYPE-R-NEW_W0QQitemZ150198178668QQihZ005QQcategoryZ18803QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Or i found these (2) Dual 2 ohms $263.98 shipped...then you would need an 2ohm stable amp
http://cgi.ebay.com/2-ALPINE-SWR-1222D-12-TYPE-R-SUBS-SUB-WOOFERS-3000W_W0QQitemZ170179787337QQihZ007QQcategoryZ18803QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Vtouch06
Q-TowN, PA
Post Number: 288
^^for Rob Smith...
