Kicker vs. rockford fosgate
Username: Foxbiker529aolcom
i am trying to decide between a kicker sub and a rockford fosgate sub.
the kicker is a 10" kicker comp.
the rockford fosgate is a p1s410 (10")
the subs are only about 10$ difference in price.
and they are both rated for the same power.
which one should i choose????
Username: Drant19
DUB-C, TX
Post Number: 139
post a budget and im sure someone on here can give you a better option than the kicker or rf
Username: Vtouch06
Q-TowN, PA
Post Number: 284
neither...there's better subs out there then those, whats your budget? and what amp r u running? you lookin for SQ r SPL im pretty sure we can help you out if you tell us that info.
Username: Rovin
4 10 Pioneer...
Post Number: 12644
both of those r pretty weak subs man
how much power has ur amp got- model no ?....
Username: 30hrtz
Raleigh, Nc U.s.a
Post Number: 153
ya but c.c and crutchfield got buy 1 get 1 free on the kicker comps.They are decent on a low budget low power system.2 12s for 99 or 2 10s for 89.hard to beat that.Just port the comps and youll be o.k.If you get hooked on bass like I did youll upgrade quickly.Comps are ok,it just takes alot of them to get loud.Im thinkin of runnin 4 c15s on my p1000.20 cuft tuned to 38hz.5 per sub.
i've only got a 400 watt amp.
im still confused, on which is a better sub.
some people say RF and others say KICKER.
Post Number: 7
i have a ported box,
if that makes a difference
IM THE REAL SLIM SHADY
Post Number: 16344
to me the kicker sounds better than that p1.
Username: Zacdavis
Beloit, Wi
Post Number: 780
Absolutely, the Kicker over the Fosgate :D
Username: Ote888
Philippines
Post Number: 13
what are the differences between these two subs??
Username: Nd4spd18
Northwest PA
Post Number: 5045
The kicker should sound better than the P1
Post Number: 11
allright..
well thanks for ur guy's help.
i think im just gonna go with the kickers.
cuz i've heard them before, and they dont sound bad.
