Audiocontrol vs TL
Username: Bonhamd
Northern, Michigan USA
Post Number: 57
Hey guys...What is the difference between an Audiocontrol and a TL? I am getting my (2) 12s tested on an audiocontrol today and just wanted to know what was different. Thanks in advance.
IM THE REAL SLIM SHADY
Post Number: 16227
just 2 different companies. it does the same thing and that is meter the db's in your ride.
now alot will say if you meter with audiocontrol, you get a bit more db's than you would with a termlab.
Username: Big_edge_head
Milwaukee, Wisconsin USA
Post Number: 1028
A TL is more accurate.
Username: Bonhamd
Post Number: 58
so the AC is not very accurate? say I hit 142 on AC would TL be more like 137 or what? Is it worth my time to get this ball park reading?
Username: Insearchofbass
Post Number: 7400
for us the audiocontrol has been pretty close to the termlab but that depends on the frequency and calibration from what im told....only one time was an audiocontrol of alot for us 3 db high but it was high for everyone so my guess is it was the boom stick mic they used because im sure people were hitting frequencies other than what we were for thier scores.....others will tell you that audiocontrol meters can be high up to 10 db but I have yet to see it and I wonder if its because the users are messing with the nob on the audiocontrol to create higher scores
Username: 04redmach1
Columbus, GA USA
Post Number: 1497
^^ Sean covered it. I have seen an AC off by 10, then again another off by 1. Just depends on calibration.
Kevin
Username: Bonhamd
Post Number: 59
Thanks guys...Is there anything I can check for or somehow have them recalibrate the AC to get the most accurate reading possible?
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 957
not many can afford a termlab tho
Username: Yukhui
3 15 AA Havocs, Memphis 4kw!!
Post Number: 810
Met a dude working at CC yesterday who had Fi BL's and a TL meter he will let me use at no cost
Username: Bonhamd
Post Number: 60
thats pretty sweet. Where do you live?
Username: Bonhamd
Post Number: 61
I want to get on the TL in the future. I am just throwing what I have in as a temporary setup. Still trying to decide on what to get in the future.
Username: Nd4spd18
Northwest PA
Post Number: 4749
I also have seen the AC meters anywhere from 1-10 db off depending on the calibration. Which makes it's reading basically useless.
The TL is always accurate as it doesn't need to be calibrated.
Username: Boomtank
Rochester, NY USA
Post Number: 446
the TL isalso cheaper then the audiocontrol. I asked for a quote on an AC and they said $1300 for the Meter and a 130db mic and $550 extra fo a 190db mic
Is here a cheaper place to get one cause i don't see how they are $1200 more then the TL( $649 for a TL and 180db mic ) and be so inaccurate.
Username: Nd4spd18
Northwest PA
Post Number: 4757
Why are you even looking for one...... its readings are useless unless you calibrate it to a TL......... and then why not just use the TL.
Username: Nd4spd18
Northwest PA
Post Number: 4758
BTW used TL meters pop up on caraudio.com classifieds from time to time.
