Silver Member Username: Dubmc23Rapid City, SD USA Post Number: 207 Registered: Sep-07 | if i wanted to get an extra 2 r's would my kx1200.1 have enough juice to run em??...the r's are the old version at 300 rms |
Silver Member Username: Dubmc23Rapid City, SD USA Post Number: 208 Registered: Sep-07 | bump |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4791 Registered: Jul-06 | If each sub is 300 rms you have more than enough power with that amp |
Silver Member Username: Bnd_rulezPhoenix, AZ USA Post Number: 926 Registered: Mar-05 | Or you could upgrade and get 2 new R's. Take up less space. |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 12623 Registered: Jul-05 | may sound better if u use 2 15s RE SE on that amp..... |
Silver Member Username: Dubmc23Rapid City, SD USA Post Number: 209 Registered: Sep-07 | cant get 15's in the trunk of my civic |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 12624 Registered: Jul-05 | so then how the heck u gonna fit 4 12s then 2 12s RE SE or some FI ... |
Silver Member Username: Dubmc23Rapid City, SD USA Post Number: 214 Registered: Sep-07 | i was actually thinkin bout fi but idk to much about em...so maybe yall could fill me in a bit? lol |
Silver Member Username: Vtouch06Q-TowN, PiStoLvAniA Post Number: 193 Registered: Nov-07 | https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=15476e03a61980c/shopdata/product_overview.shopscript |
Silver Member Username: Vtouch06Q-TowN, PiStoLvAniA Post Number: 194 Registered: Nov-07 | https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=15476e03a61980c/shopdata/product_overview.shopscript |
Silver Member Username: Vtouch06Q-TowN, PiStoLvAniA Post Number: 195 Registered: Nov-07 | hmm...sorry dude double post n it dont work, wus tryin to give u the www.ficaraudio.com site |
