Nfusion or tessat????
Username: Danoh
Post Number: 111
i believe nfusion is 4 usa and tessat is 4 canada.i live in canada but i cant find much info on tessat.is there more then 1 model,how much r they.any info would be appreciated
thx
Username: Danoh
Post Number: 112
thanks 4 the info.i guess use peaple rather f#cking tiff with each other rather then giving info.
Username: Extremex
Post Number: 80
I dont think they even make tessat any more. And from what i heard the last ones that rolled out didnt use IKS.
Username: Tale
Post Number: 65
Try here !
http://www.topfta.ca/DisplayDetail.aspx?pid=140&cid=28
Username: Danoh
Post Number: 113
thx 4 the respose.i see on most sites have files 4 nfusion but no heading even 4 tessat.i know all u have 2 do is plug it in wirless router and it updates automaticly.but what if u have to manully update????
Username: Nydas
Post Number: 6194
http://www.ftatlk.com
has a separate heading of Tessat and there was even a post there saying "it is illegal for Canadians to won a nfusion" and vice versa.
Username: Krishn
Post Number: 31
Nalin - first you have a typo in your URL, it should probably be ftatalk.com not ftatlk.
Second this URL - http://www.thedigitalstore.com, sells Nfusion from Toronto and other places in Ontario, they even offered a cash and carry discount of 5%, it seems they have removed it now for nfusion due to demand.
Username: Pulp_fictionass
Post Number: 44
Me and Nalin got you covered go to our private forum for the newest files
