Whats best high def box in the market ?
Username: Lomna
Would like to one HD Fta box. Need your advice !
Username: Scabz
Knoxville, Tn Us
Post Number: 159
None is best right now. I heard that you need to purchase a seperate part that cost $200-$250. just to get it to work.
Username: Taran420
Post Number: 34
u heard it right and wrong scabz
all hi-def boxes are ready to got with BEV HD channels
if u want to get DN HD channels then you need to buy an Adapter worth about 180$, then you would get all the hi-def channnels
BEV = 50 HD Channels
DN = 180-200 HD Channels
currently i own an sonicview 8000HD and i love it. it is the best HD box in the market right now
their is viewsat 9000HD but its not the best in the market. its failry new and their are alot of bugs
so i would hands down recommend sonicview 8000HD, price is about $400-450 + adapter 180 = 600$ and you get all the hi-def you can get
ftaview.com
Username: Lomna
Thanks to scabz and realgum !But really wondering ,why we need adapter for dn not for bev when they are using same technology !
Username: Lomna
what about motorola fta box?
Username: Way2smart
Http://www.dssworld.co..., Zeeshan Ashiq DssWorld Mod...
Post Number: 367
The Best is viewsat 9000hd
Username: Boboshan
Somewhere, Out There
Post Number: 47
devin, dn & bev are NOT using the same technology. bev is actually using a somewhat older method for broadcasting hd where as dn's is newer.
Username: Lomna
Post Number: 7
Thank you both shan and smart...
Username: Oleg1474
Florida Usa
Post Number: 706
NaGrA-3 COMMING SOON !!! New (euro/ecm666) B3v fix ViewSat fix now. Next step PanSat fix TEMP. now; Thank you Oleg PHD.(ALL CHAN. TEMP-OPEN new prog.BIN@EURO/ECM-12/20/07)
Username: Mrsofty
Platinum VIP Member
Post Number: 134
you might look at the Neusat 9000HD its Cheaper about $160 .. according to where you live and what you want to receive really
look here for Neusats
[link removed]
Username: Mrsofty
Platinum VIP Member
Post Number: 135
if your in Botswana like me and a little more if your in the states but still less than the others
