PCI DVB card
Username: Golam
Guys please take my questions kindly. how does the DVB PCI card works? Does it require any internet access like nfusion? What kind of software do I need?
I would appreciate if someone kind enough to answer my questions or direct me to a site with information. Thank you all.
Username: Viruscauser
Leesburg, Georgia
Post Number: 563
http://board.mytheatre.ru/
Username: Golam
thank you abby
Username: Grearz
Post Number: 8
if setup properly this is the sweetest setup by far. My theatre, with sage tv, pvr, you can card share over the internet. much diff then working with the stb's. I can access my sat server from anywhere in the world and stream the guide and watch tv. also checkout sage tv forums as well.
cheers
Username: Nydas
Post Number: 6170
golam chow: If you understand internal cards for computers, you will understand DVB Cards as well.
There was need for computer ourput to be visible and they developed video cards and later faster video cards (AGP cards).
There was a need for a Parallel port and a couple of serial ports and there was a card for doing this 2 serial and one parallel port and somebody threw in a game port
Somebody said why not a TV card, so they developed a TV card that took the signals from the antenna and after processing they put out a TV signal for any video monitor to display TV.
They did th esame thing to DVB (Direct Video broadcast) from satellites, and as far as the FTA signals are concerned, you have TV.
Somebody said, that the computer is powerful enough to decode Nagravision, so they developed a decoding add-on. somebody else said that it uses too much computer resources, so why not have a special CPU on a card and let the computer's CPU free to do its own thing. somebody else said, instead of watching tV locally, I want to watch it 200 miles away, so, he encoded the output of the DVB card and packetised it to send it via Internet to anywhere else in the world. There essentially are 3 types of DVB cards. You have to read the specs carefully and see if the software available is propritory or Open source. Also study which of the above mentioned features you need and if they are there.
Username: Golam
Thank you Nalin....good information. I'm a computer hardware guy ... i know about all sort of video cards. Any other source of information? Do you think Twinhan would be good investment for this? Much Appriciate it.
Leesburg, Georgia
Post Number: 564
I have had my Twinhan VP-7021 for over three years now and have never had a problem with it.
Have not looked into what's available today but I'd guess there are much better and much faster HDTV cards out there.
I'd suggest buying an external card like mine though.
Username: Golam
Abby, is your Dish internation up with the twinhan?
Leesburg, Georgia
Post Number: 566
DN wide open: Int, PPV, XXX, Movie channels and all.
Username: Tigger_woods
Post Number: 284
Are DVB cards up?
Username: Nydas
Post Number: 6200
Abby: What is the software that is on top of Linux and before the Emunation
Username: Cybermaster
Post Number: 102
what about DIGIWAVE EXTERME HDTV ATSC DVD FTA PCI TV TUNER CARD. this is an HDTV card. has anyone used it. what files would be compatible. Any feedback will appreciated. Thanks.
http://cgi.ebay.com/DIGIWAVE-EXTERME-HDTV-ATSC-DVD-FTA-PCI-TV-TUNER-CARD_W0QQite mZ120139223106QQihZ002QQcategoryZ32848QQrdZ1QQssPageNameZWD1VQQcmdZViewItem?_trk sid=p1638.m118
Username: Luka
Abby, what OS are you at (XP, Vista), Twinhan driver (original? 3rd party? version), application (MT? DD? version), cam (emunation? vplug? version).
Appreciate your help, thanks.
Username: Psychmonster
Rhodium MemberAint nuthin ...
Post Number: 271
wow...at last a thread with some genuine give and take...very refreshing
Username: Ke5aqn
Post Number: 2039
Also the dreambox does all of this as well without having to be installed INSIDE a computer...well worth you looking into. I have found by googleing or ebaying prices aroung 120 for a dreambox 500.
http://www.ftalinux.com/phpBB2/
Post Number: 103
Anything about DIGIWAVE HDTV pci card.
Username: Ke5aqn
Post Number: 2042
http://www.google.com/search?q=DIGIWAVE+HDTV+pci+card&ie=utf-8&oe=utf-8&aq=t&rls =org.mozilla:en-US:official&client=firefox-a
google it!
Leesburg, Georgia
Post Number: 567
My setup is:
Win XP Pro
Twinhan VP-7021
MyTheatre 3.38
Emunation
That's all you need really.
I knowledge about these things is very limited: Some use DVBDream or other similar Progs instead of MT and some use Linux instead of Windows but I wouldn't know about all those. There are a myriad of DVB cards available too but my Twinhan is the only one I've used or know anything about.
Username: Ke5aqn
Post Number: 2061
Abby,
whats your processor speed and memory on that machine?
Leesburg, Georgia
Post Number: 568
1 GB
Intel Pent IV - 2.66GHz
NVIDIA GeForce4 MX 440
Username: Luka
Thanks Abby,
I wish... I've played with VP-7021A about a year ago and my experience at the time was you need to try countless combinations of driver-app-cam until you get one that is satisfactory. Last app not necessarily worked nicely with the last driver, not to mention cams. Unfortunately, my VIA 1GHz board was too slow to play B3V HD (even with hardware mpeg2 decoder onboad) so I gave up. I'd give it another try with my new laptop.
Do you use driver from Twinhan site? Do you know if it works for Vista?
Thanks.
Username: Ke5aqn
Post Number: 2066
Luka,
I was just thinking I bet its a fight to get it all working under windows with all the driver issue's......I would run it in a linux environment I bet the Linux users have it working! I am ordering a DreamBox as soon as I can its a Linux operated box....
Leesburg, Georgia
Post Number: 571
MT comes with all the Twinhan drivers that you'll need but you can get the latest drivers for the Vista from the manufacturers website if you need to.
I don't know about the Vista but I've not read anything about Vista problems on any of the sites I visit so it's safe to assume that using Vista poses no problems at all.
I have to admit a lot of frustration when I first tried to set it up and finally got it working through help from the very helpful members at the MyTheatre support forum. I'd strongly suggest you give it another try.
Username: Luka
CyberMaster, from brief look at it DIGIWAVE EXTREME HDTV doesn't appear to be DVB card. It is for terrestrial broadcasts.
Re Dreambox, another option could be CaptiveWorks 3000HD. It's being sold as FTA receiver, but from what I see in their description it's just a regular PC with (unconfirmed) Skywalker-1 DVB add-on card, all in a nice HTPC case. If it indeed has Skywalker ($300 DN HD capable card) than at $480 it sounds like a bargain.
Username: Vittu
Post Number: 84
Luka. I just ordered Skywalker-1 to get all HD that BEV&Charlie has to offer including mpeg4. I also upgraded my video card to ATI HD 2600XT. Can't wait..
Username: Golam
Abby I just bought Geniatech SatBox Satellite USB Box http://www.sat-sales.com/proddetail.php?prod=SatBox_Satellite_USB_Box
It supports Mytheatre, ProgDVB.
Any suggestion or thought?
Leesburg, Georgia
Post Number: 572
Like I said, I know just one card but the info you linked shows nothing to worry about. I'd expect this to work just great.
Now might be a good time to visit http://board.mytheatre.ru/ and learn the setup basics while you're waiting for this to arrive.
Username: Luka
The FTA Tester, that's why I bugged Abby with precise info. Once someone get working combo it's just a matter of install exact same components.
Linux IMHO is the best environment for developer (or tester :-). You can tweak it any way you like, but could be a challenge if you havn't dealt with it before.
Username: Ke5aqn
Post Number: 2080
I am getting the dreambox next week. I will get it all up and working then Make a nice "how to" for all to use...
Username: Luka
Vittu, I'd appreciate if you write-up your experience once you get it working. BTW, where did you order it from, how much? Thanks.
Username: Grearz
Post Number: 9
I've tried some of the linux apps and for those who want a sweet dvb setup. Learn some xml scripting and use the sage tv plugin with my theatre. full mpeg4 hd recording. can automatically convert to divx, burn. you can use the haupage medi centres and flash with sage software adn with eace media centre you have a seperate satelite box in each room using rj45.
I do open card sharing with a friend's server so it barely goes down. I love linux but the linux pvr apps are more buggy. ne how, this is porbably way more advanced than what you've seen out there. go to my theatres forum and search sage tv. just trying to open you up to something different.
Username: Thadragun
Kingston, Ontario
Post Number: 41
THE FTA TESTER, I'm not sure if you live in US or not...did you get a dreambox with American tv connections? I'm not going to buy one, I just bought a new VSPRO a little while ago, but I was just curious about them just incase I wanted one later on. Thought I'd look into them to see what its all about. They look pretty good but all the ones I've seen have Scart(?) tv connection. None available for US/Canada?
Username: Luka
Post Number: 7
The FTA Tester, that would be nice thing to do.
Username: Ke5aqn
Post Number: 2103
The ones I found on ebay and all around the nett are USA ready.....and yes i will right a review of it after it gets here...
Username: Luka
Post Number: 8
gman, I was under impression MyTheater is Windows app.
Username: Grearz
Post Number: 10
It is, I use a sony dual amd server with 1 terabyte for media storage and windows 2003 a the o/s. Dedicated only to sage. You need a very good graphics card as well. most new cards are fine, at least a pentium 4 , I prefer amd, runs cooler. Cost a little more to setup than buying an hd stb. Servers don't cost too much these days. TWinhan cards are probably better. not sure if i'd trust the digiwave. the above link by Abby is all you need to start your search.
Username: Vittu
Post Number: 85
Luka: I ordered it from hxxp://www.genpix-electronics.com/ for $322CAD. You cannot buy it from anywhere else. The reason I bought it because it's much cheaper than buying a HD receiver ~650. This USB 2.0 adapter supports both MPEG2/MPEG4 for any provider and has built in all qpsk/8psk etc and can do much much more than a FTA HD receiver. I should be have it before xmas and will give my feedback on this unit.
Username: Luka
Post Number: 9
Thanks Vittu,
My thought was if CaptiveWorks 3000HD really uses Skywalker as it's sat tuner than it's well worth $480. If it uses some other and only supports SW as add-on, than it's another story. For now I'll be happy with $30 Twinhan 7021A. B3V's Discovery and the like are all I need in HD. I guess, I'll need to do more research on CW3k. Please let me know if SW-1 worked well for you once you get it.
Username: Golam
Post Number: 7
Can someone point me to the latest version of Emunation. Are the internationals on Dish really up with this?
