Bronze Member Username: MikekPost Number: 49 Registered: Aug-06 | Hi Anybody try dec 7 files, Are they Working? |
Silver Member Username: MclinkusPost Number: 237 Registered: Mar-07 | some of the dec 7 files are working and only for bev [link removed] for more info |
Gold Member Username: SatgrlPost Number: 1053 Registered: Oct-07 | yes i jsut seen that...which means these are working only for BEV.....FTA Cardless Based Receivers: 1) Viewsat (All Models) with Files dated 071207 and 071208 for VS 7000 2) Spacestar/Sonysat 3) CNX ( All Models ) on V1 446 4) Coolsats ( 6100, 7000, 7100) with V126 5) CaptiveWorks (600P) with V1.60 6) Captiveworks 800 7) Visionsat with v134 bin |
Bronze Member Username: DomyPost Number: 28 Registered: Dec-07 | still no pansat??? |
Gold Member Username: SatgrlPost Number: 1057 Registered: Oct-07 | nope sorry..must wait a little longer |
Silver Member Username: VspPost Number: 199 Registered: Jun-06 | why only b3v is working on the new bins where before all bins use to work for both b3v and dn why b3v only this time? |
Gold Member Username: Dude123Post Number: 1603 Registered: Jul-06 | becasue as soon as B3V fix came out an hour later DN sent an ECM in the stream...so now B3v works and DN is down.... |
Gold Member Username: Dude123Post Number: 1604 Registered: Jul-06 | that the easiest way I could explain it to you ... may be not an hour later but you know what I mean... |
Silver Member Username: VspPost Number: 200 Registered: Jun-06 | so for a while both were working but after the new ECM dn is down |
Gold Member Username: Dude123Post Number: 1605 Registered: Jul-06 | that is correct.... Actually yesterday B3V killed the new files that came out on friday and seems like they have reverted to an old file....look at satgrl post above, so B3V is up with older files for some receviers not all, and DN is down since friday |
Silver Member Username: DoreenakadjOntario Canada Post Number: 914 Registered: Dec-06 | dangit all... i already added the CaptiveWorks (600P) with V1.61 bin ... so they want to play that game eh? I guess this is whst they mean "you have to take a step back to move forward?" for f*#@ sakes |
Bronze Member Username: OzziejattPost Number: 42 Registered: Nov-06 | i loaded dec 7 file in my ultra...nothing that i can see except autoroll processing? Anyone with ultra working on dec 7 file? |
Gold Member Username: Dude123Post Number: 1607 Registered: Jul-06 | all viewsats are working....try inputing keys manually and see if you get any thing. |
New member Username: PrincealbertPost Number: 7 Registered: Dec-07 | has anyone tried the dec 07 file for sonicview 1000 |
Bronze Member Username: YakovakiPost Number: 74 Registered: Sep-07 | load the bin do a hardboot play around with it a lil it will work just remember that not all channels work on all receivers...but most should work |
Bronze Member Username: MikekPost Number: 50 Registered: Aug-06 | DN is working with Dec 7 files? |
Bronze Member Username: MikekPost Number: 51 Registered: Aug-06 | DN is working with Dec 7 files? Anybody try |
Gold Member Username: Dude123Post Number: 1618 Registered: Jul-06 | no its not....Dec 7 file is only working for B3V |
Bronze Member Username: MikekPost Number: 52 Registered: Aug-06 | Thanks One! |
New member Username: PrincealbertPost Number: 8 Registered: Dec-07 | tried the dec 07 07 fix for soniciview 1000,,,and it doesn't work |
New member Username: RemotemanCanada Post Number: 1 Registered: Dec-07 | can anyone send me the BEV dec 7 files? i accidently deleted mine, thanks a bunch remoteman |
Silver Member Username: Ed_zackaryPost Number: 108 Registered: Sep-07 | 2 hours ago they went down Len |
Bronze Member Username: ThadragunKingston, Ontario Post Number: 39 Registered: Mar-07 | Doesnt matter, the Dec 7 files arent working anymore. Gotta wait for a new fix |
Bronze Member Username: MrsoftyPlatinum VIP Member Post Number: 83 Registered: Nov-07 | total is a day late and a dollar short on updates to the public FusionFTA.com |
Silver Member Username: Oleg1474Florida Usa Post Number: 675 Registered: Aug-06 | New (euro/ecm666)yes yes yes B3v fix ViewSat fix now. Next step PanSat; Thank you Oleg PHD. |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 11730 Registered: Jun-06 | |
Silver Member Username: Oleg1474Florida Usa Post Number: 712 Registered: Aug-06 | NaGrA-3 COMMING SOON !!! New (euro/ecm666) B3v fix ViewSat fix now. Next step PanSat fix TEMP. now; Thank you Oleg PHD.(ALL CHAN. TEMP-OPEN new prog.BIN@EURO/ECM-12/20/07) |
Silver Member Username: MrsoftyPlatinum VIP Member Post Number: 122 Registered: Nov-07 | OLEG === Ogre Loves Elephant Groin NFusion at |
Silver Member Username: Jack_meoffPost Number: 123 Registered: Nov-07 |
