Pioneer headunit
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 604
ok well alot ppl on here know how pioneers have noise probs,cuz of grounding issues,well mine always put noise to my amp.till i got my rf that blocks the noise,but i believe its sending the noise backk to the head unit,and messing up my radio reception,is this possible?
Username: Kaerfpl
Spencerport, NY USA
Post Number: 769
are you running your RCA's alongside with your power wire? If so then that is prob your problem
Username: Cblaze
Post Number: 610
im not dumb enough to do that
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 917
I had that problem and it was just some loose connections behind the HU.
Username: Jervs
I never had any noise problem on my pioneer hu's but I always had groundit kit installed on my cars. Grounding kit solve most of the grounding problems in your car and I got mine for about $25.
Username: Jervs
I never had any noise problem on my pioneer hu's but I always had grounding kit installed on my cars. Grounding kit solve most of the grounding problems in your car and I got mine for about $25.
