Atmega 128 or ROM 102
Username: Imauser
Post Number: 32
I am going to buy Atmega or ROM 102 card. Can anybody tell me that which one is better and why? Would you recommend Atmega or ROM 102 card. In the past I had "ROM 10" card. Is "ROM 10" card still good to reprogrammed? Pls let me know...THanks
Username: Mufta
Post Number: 182
ROM 102
No emulation available for ROM 10...
Username: Imauser
Post Number: 33
Thanks
But I heared that both cards works the same. Atmega card cost only $30.00. However ROM 102 card cost over $100.00. Why I shouldn't buy Atmega?
Username: Mufta
Post Number: 184
Problem with Atmega is the flaky support, whereas ROM102 is much stable and fixes are quicker.
I never used atmega but I beleive for atmega you need computer too...
But ROM 102 is the best option so far.... support is perfect...
Username: Imauser
Post Number: 34
Thanks for your advice
One last question
I heared a lot about Nfusion and Dream BOX as well. Would you recommend me buying Nfusion or Dream Box instead of spending money on ROM102 card? Pls let me know.
Username: Mufta
Post Number: 186
No problem!
I would go for Dream Box.
I think you should do a comparison and wait for other forum members input too...
Username: Imauser
Post Number: 35
Thanks
