Doreen???
Username: Mrkhan
Post Number: 42
hi Doreen, thanx for the file, I got, but got a problem, when I download to my desktop, and when I click on it, it gave me a message saying,( To open this file windows need to know what program created it. Windows can go online to look it up automatically, or you can manually select from a list of programs on your computer. Is it suppose to download as podconv.rar?
Thanx
Firoz
Username: Steph_raven
Cartier is my boy toy!..., U wanna play... Canada
Post Number: 247
Firoz...if the software is .rar.....you need to download winrar. goto http://www.win-rar.com to get it. you'll be able to open Doreen's file
Username: Doreenakadj
Ontario Canada
Post Number: 945
Thanks Stephan... yes use WINrar. After you get it loaded onto your PC any winrar file will now have the icon showing up ... Right click on the podconv.rar look for "Extract Here" i would extract it onto your desktop (easier to find) an EXE file called "dvd-to-ipod-converter.exe" should be on your desktop along with a TXT file called "ImTOO DVD to iPod Convertor 4.0.90 [Build-1018].txt" read that first before installing the ImTOO DVD to iPod Convertor exe.
Install the software
After it is up and running go to "help"
Then look for enter registration code
Where it says NAME type in ...TeamICU
Where is says license code type in ...
45B4-D26J-7987-5SS9-3B74-7B47-EDC7-BCD7
Push OK your done and it should say registered successfully
I installed it on my own pc with the crack codes and it works .
enjoy the softeware
Username: Mrkhan
Post Number: 43
Doreen.....& Stephane.......!!!!!!!!!
Thank you thank you thank you so much guys. I did it and it successfully register. Once again thank you so much guys. Now lets see if I can convert a movie into the ipod format :-) otherwise I have to bother you guys again :-)
Firoz
Ontario Canada
Post Number: 946
your are most welcome firoz glad to help
Post Number: 250
you are welcome...good luck and enjoy!!
Username: Pulp_fictionass
Post Number: 14
Enjoy your fried box
