Why doesn't my sub amp turn on when...
Username: Skibum12189
Cleveland
Post Number: 2214
the car is on accessory....
I have one remote wire run from the back of my HU to the sub box where its split into two....When the car is not running, but on accessory, the HU is on, my Nine.4 is on (speakers on), but my Nine.1 is off (subs off)
any reason for this?
Username: Texas_bass
Houston, TX
Post Number: 564
your split might be bad check the wires
Username: Nd4spd18
Northwest PA
Post Number: 4674
Measure voltage both amps REM terminals and post it here.
Cleveland
Post Number: 2215
well thomas thats what i figured but when the cars on they both work fine
ill work on that m.s.
Username: Van_man
Boston South, MA
Post Number: 3191
Your sub amp wont turn on if theres not enough juice. If your battery is sitting under 12 volts, it may not sence enough power and stay off, like a protection feature. Like M.S. Use a volt meter and test battery, amps, and rem wire voltages at accesory position, and when running.
