Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 374 Registered: Feb-07 | or what i'm trying to say is what is the biggist power wiring i can get? and were? links! thanks! |
Silver Member Username: Vtouch06Q-TowN, PiStoLvAniA Post Number: 133 Registered: Nov-07 | http://cgi.ebay.com/KICKER-PKD1-1-0-AWG-GAUGE-DUAL-AMPLIFIER-AMP-WIRING-KIT_W0QQ itemZ120199814415QQihZ002QQcategoryZ79815QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Gold Member Username: JakeyplaysbassASU Post Number: 2207 Registered: Jul-05 | 2/0 is bigger than 1/0. theres a very good chance you wont need to run anything bigger than 1/0 however. |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 376 Registered: Feb-07 | hey jake is there a website i can get 2/0?? thanks man |
Gold Member Username: SouthernrebelMonroe, Louisiana 2 DD3515s, 2... Post Number: 5704 Registered: Mar-04 | www.weldingsupply.com Welding cable. |
Gold Member Username: JakeyplaysbassASU Post Number: 2208 Registered: Jul-05 | if you really need it i would just have 2 runs of 1/0. ive only seen one car before with 2/0 and he was running over 15kw for comps. |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 377 Registered: Feb-07 | ok thanks man i will just run 2 1awg |
Gold Member Username: JakeyplaysbassASU Post Number: 2209 Registered: Jul-05 | how many amps are you running? anything under 250-300amps and u should be good with 1/0. if your running over 300amps do 2 runs of 1/0 or a run of 2/0 if you really want too, its not really needed tho. |
Gold Member Username: AdddisorderPalm Beach, Florida Post Number: 5637 Registered: Jan-06 | biggest you can get as far as i know is 4/0 |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 396 Registered: Feb-07 | how about this website any good?? |
Gold Member Username: ShortysetniesRock Vegas, NC US Post Number: 1535 Registered: Mar-06 | link? |
Silver Member Username: Big_edge_headMilwaukee, Wisconsin USA Post Number: 986 Registered: Mar-07 | nick v runs 3/0 ask him. |
Gold Member Username: camBC Canada Post Number: 1322 Registered: Nov-06 | Don't forget to fuse each run separately. |
Silver Member Username: SomedonniedudeIllinois United States Post Number: 579 Registered: May-07 | Whats the difference between 1/0, 2/0 and so on? I thought the first number was how many runs of 0 guage the kit included. |
Gold Member Username: camBC Canada Post Number: 1326 Registered: Nov-06 | Nope, it's the gauge. It goes down with even numbers, 'til you get to 1, then you have 1/0, 2/0, etc. |
Silver Member Username: SomedonniedudeIllinois United States Post Number: 580 Registered: May-07 | I just read a short thing on it, on a chart I found it said 0000, 000,00, 0, 1, 2, 4 etc. So basically the first number is how many "0" are in the gauge size? What does 0/1 mean? Does that mean 0 guage/ 1 run? |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4669 Registered: Jul-06 | 0000 = 4/0 000 = 3/0 00 = 2/0 0 = 1/0 see a pattern? |
Silver Member Username: SomedonniedudeIllinois United States Post Number: 582 Registered: May-07 | Yes, I now understand that part. I just dont know what 0/1 means... like this http://www.sonicelectronix.com/item_3935_Kicker+PKD1.html |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4676 Registered: Jul-06 | If you look at the subtitle it says " Dual Amplifier 1/0 Gauge Power Installation Kit 05PKD1 " So I guess they just wrote it backwards in the description. |
Silver Member Username: SomedonniedudeIllinois United States Post Number: 583 Registered: May-07 | Then I guess my questions are cleared up. Thanks MS. |
