NFusion Nova PVR FTA Satellite Receiver
Username: Vndpatel
Post Number: 284
I was thinking about getting one of these abd gettin rid of my pansat. is it worth it? i herd you dont have to do anything when dishnet goes down. it deos it by it self.
Username: Vndpatel
Post Number: 285
and wats a good site to get on at?
Username: Alftabin
Post Number: 14
what model of pansat you have?
Username: Vndpatel
Post Number: 286
Username: Alftabin
Post Number: 15
same as me...
Username: Ajaz9434
Post Number: 14
is pansat ppv and international channel working
Username: Vndpatel
Post Number: 289
ok
Username: Vndpatel
Post Number: 290
wats a good site online to get one? any one know
Username: Chessy
Post Number: 38
where are you located at..
Username: Vndpatel
Post Number: 299
in massachusetts
Username: Johnner
Miami, Florida
Post Number: 1371
Copy&Paste
Units using IKS (Internet Key Sharing) such as Nfusion are running. That means it is connected to the internet and relies on an aux server to get its video authorization "keys" to the clients. It does'nt stream over the internet, but they are getting the keys from a open rom 102,103 application and then sending through IKS. You do expose yourself to giving your IP ADDY to those that want it to track you down though.
http://www.dssrookie.com/forums/status-report/dtv-dish-fta-status-report-77311.h tml
Username: Vndpatel
Post Number: 301
man johner i havent seen u in a while.
Username: Johnner
Miami, Florida
Post Number: 1372
I know; too many things to do...
Not as much time in my hands anymore! LOL
Username: Ez2ctv
Platinum Mem...
Post Number: 16
They can have My IP, but it's not mine!
Ever heard of AIRCRACK ? Google it OR BACKTRACK. All the tools of PENTESTING are on BACKTRACK.
There's more in the air for free than FTA
Username: Johnner
Miami, Florida
Post Number: 1373
LOL, I've used it before!
Username: Ez2ctv
Platinum Mem...
Post Number: 18
Good place for Nfusion / Captiveworks
http://www.trusssatellite.com/Scripts/default.asp
Username: Vndpatel
Post Number: 302
so wat do you guys recommend i do? stick with the pnsat sat or get the nfusion? tony u got a nfusion?
Username: Kingofdakingz
Post Number: 46
does nfusion goes down and is there any problem getting it ??
Username: Vndpatel
Post Number: 303
it does it by it self so if the bin changes or keys change u dont have to get anything it does it by it self
Username: Ez2ctv
Platinum Mem...
Post Number: 20
Don't have a Nfusion yet. Several people I know Have it and are very happy. I Have Captive Works products, I selected the CW800 over the Nfusion for the PVR function as the people I know that have the NFusion like the way the CW800 works in that regard better than the NFusion.
The NFusion is not perfect on IKS there are problems with short drop outs etc. But I have to say that the support for the NFusion so far has been second to none.
Captive Works does have the ability to do CARD SHARING, that may still be a option if the current state of events go much longer than a few more weeks that some say it will take to do a new emulation for FTA boxes.
After that time I will look again at a NFusion as so far their IKS seems to be the best. I just did not want to invest any more into the hobby until I get a better picture on the future of Mpeg4 and Better offerings of HD in the FTA arena.
Username: Vndpatel
Post Number: 304
does nfusion ever go down?
Username: Tale
Post Number: 67
Any good support site or guide for NFusion ?!?
