F*uck nfusion is out of stocks............
Username: Saqeeb9000
Post Number: 885
i called 10 sat stores.........nfusion all gone.......................................................
Username: P0tzzz
Post Number: 20
I see alot of those receivers on fleabay...good luck.
Username: Pulp_fiction
Post Number: 821
no surprise....
word to the wise...depending on what system u have now will depend on what u can do later...
if U start searching google for information on
Aux Share
Aux Server
Card Sharing
IKS
u might just get a jump on things....
Username: Dickfoil
Post Number: 75
pulp
[link removed]
Username: Pannu16
Post Number: 681
sada its avialable at stores in ssauga!! or goto ebay man!!
Username: Dickfoil
Post Number: 76
forgot...heres another good one
http://www.satspies.com/forums/
Username: Chessy
Post Number: 37
what area you looking in ???
Post Number: 890
calgary.. some thing in stock...today... ....
Username: Lokbongtom
Post Number: 42
Remmeber any stb on the market has a limit time supported,even if the Nfusion.Don't expect to buy any new model in order to watch a free tv for ever ,it is impossibe
Username: Bigspud
Post Number: 18
ur best bet is a dvb pci card, been using the same one fer 5 years. i actually have 2 in my puter so i can watch and record 2 dif sats at once. did i mention that since all b3v purn on same xponder, u can record or watch all 10 purn channels at once using dvb dream software? did i mention hd is viewable also, though u will need a decent cpu. all from a $80 pci dvb card.
Username: Ke5aqn
Post Number: 2036
get a DREAMBOX its does so much more
dreambox
http://www.greatdvb.com/dreambox-DM500s-original.htm
and around 120 on ebays all the time so 1/2 the price
Username: Dickfoil
Post Number: 83
so what does the dream box run on....v-plug ,emunation or a bin?
Username: Opie
DEEP SOUTH
Post Number: 29
Derambox runs on images and cams.
Fta Tester: Did you finally get yourDreambox?
Username: Dickfoil
Post Number: 85
so you need an unlocked 102?
any good sites to go to read about this?
Username: Ez2ctv
Platinum Mem...
Post Number: 14
In stock at this location, Pick-up or free shipping http://www.trusssatellite.com/Scripts/default.asp
Username: Flagmax
Dreambox users: Since it uses images, do you still have to wait as with other boxes? Or is it open source and you can make your own images?
Is there any tutorials or info on how to start coding yourself?
If you can't, whats so good about them?
Username: Matito
Some body can help me out how to get Puerto Rico local channels I live in Florida.
They coming on 110 sat but I don know if I need an special Lnbf with different frecuency
Thanks a lot
