IKS vs Emunation
Username: Lolol
Post Number: 194
Whats the difference between the two? I thought they were both kind of same thing...Am I mistaken? Is IKS faster than the Emunation system? Can someone explain it in a little more details?
Regards,
Username: Pulp_fiction
Post Number: 795
IKS is internet key sharing
emunation is a emu for dvbcard's just like opencam is for linux based system..
Username: Birdwatcher
Post Number: 578
yeah so go and get it this instant. Get caught with solid evidence that your a pirate!!!!
Post Number: 797
and as Abby reported emunation is up on dn dealing with the map3e
but they haven't realeased the source so STB's might have to work at ripping it this time...
Post Number: 581
I love file ripping in the morning!! first thing of course
Username: Nydas
Post Number: 6086
Linux based software will eventually become the legal way to "piracy" as currently defined.
Username: Cartier1
Post Number: 1535
nalin nyda if u ever saw someone with emunation i wanna ask when u transfere to watch on tv , how is the pic quality? cuz i would never watch my tv on computer screen. thanx
Username: Jagr1234
Post Number: 118
its ok...not bad not great.
tv out, rca plug to television
twinhan 1027
Username: Nydas
Post Number: 6092
1. "i would never watch my tv on computer screen".
ON 21" LCD you do get very good picture using
http://idesiTV.com
2. "when u transfer to watch on tv"
That's exactly what you do.
When you install a DVBCARD, you have a TV signal out on the card which goes to your regular TV.
3. Much has been written about cards with on board CPUs and memory, and cards which use computer's CPU/memory
Username: Jagr1234
Post Number: 120
to add more....its similar to the pic you would get on pansat 2500 on a tv
nalin is right it may be a real good picture on an large lcd. the pic is better on my lcd pc monitor compared to tv. same card
Username: Cartier1
Post Number: 1536
does the card have tv out . cuz i heard lot of them dont have tv out . also if u know about one that has usb to use in my laptab.and remote .
thanx lot
Username: Jagr1234
Post Number: 121
i have used tv out on pc for last two set ups. newest card appears to have tv out but I did not get a picture testing it. so i just use the pc tv out card. 13 bucks on ebay when I bought last Tv out card for a pc
Post Number: 802
Emunation all ready back up on veb... They are using the same mecm as dish now so use the prov 0101 emu
Post Number: 803
if u get a card with s-video picture qulaity not bad..plus most s-video/composite out cards have a great control panel which u can tweak it to ur liken...
Username: Cartier1
Post Number: 1537
my laptab has a s-vided out put, i just tried to play dvd and connect it to tv to see if i can get picture just for testing ,cuz i never done it before and i could not get any picture. m i missing anything ?
Username: Jagr1234
Post Number: 122
your laptop with s vid out should work for dvd. you will need sound cables too
Username: Cartier1
Post Number: 1539
plz anyone who knows about emunation .if this box will work for emunation . i have a laptab and im looking for something with the usb instead of pc .
this the link: thanx in advance.
http://cgi.ebay.com/GeniaTech-Satellite-DVB-S-FTA-USB-Receiver-HDTV_W0QQitemZ330 197908563QQihZ014QQcategoryZ32848QQcmdZViewItem#ebayphotohosting
Username: Dickfoil
Post Number: 65
i hate to tell you this but your going to have to look around at dvb sites or dvb sections. all these devices can be quirky with different computers combined with different cards. some set ups seem to work better. these dvb set ups are very time intensive to set up ...a lot of reading a lot of scanning and trying different codecs and video graphs. the viewing programs can be buggy , depends on your set up. i would go with a pci card if possible.
Username: Luser
I have that card twin han 1027 in the pci version.I had to use drivers called digitaltv3.3 and then use vplug or emunation with my theater or dvbdream.If you get an error you have to restart your computer.Once working it has an awsome picture on a 42" plasma.Hd but not 8psk only a few qspk on 82 bev.
Username: Cartier1
Post Number: 1540
dickfoil thanx .
semore thanx . i just ordered one and never knew how this is gonna work.
once u instal the card what is the story with emunation 3.o.o.3 i mean how to do it so i can be able to open the chanels . is there any set up step by step on how to do it ? thanxxxxx
Username: Cartier1
Post Number: 1541
semore does 1027 has the output to the tv?
Username: Dickfoil
Post Number: 70
[link removed]
dig around....i think these had how to's. plan on killing a couple days setting this up
fta.bins for MT or DVB DREeam
i dont know if you want to take advice from though. im new so i must be a bad person
Username: Cartier1
Post Number: 1542
no u r trying your best and im not gonna forget this . i will give u back the favor one day . :-)
Username: Dickfoil
Post Number: 73
im still tweaking mine. different setups for dishpro and legacy LNBS. you have to check out a lot of things....
no problem...your welcome
Username: Luser
No tv out.You need a seperate video card unless your laptop has s video out.For emunation you just put all files in your dvbdream or my theater plugin folder and one file called pthreadVC2.dll in the root and it comes with a link to install visual c++.Then you can watch the emunation monitor as it finds the keys for different providers or now for bev, map:ce not supported.
Username: Cartier1
Post Number: 1543
im sorry i have a question . when u watch on tv do u use the remote that comes with dvb card . and changing from channel to channel is it fast ? is it just like the stb? thanx guys
Username: Dickfoil
Post Number: 87
cards come with a remote and a remote sensor that plugs into the card.
the remote also takes some tweaking pending which epg prog you use. it isnt perfect but it works.
Username: Luser
Compared to stb its a big pain in the azz.I only like it for its 1080I.It freezes up and you'll have to restart your computer to get the drivers started again.Channel names are 4letters and doesnt seem to handle 4 sats well.It also requires 2g prossesor.It ran a little longer than my viewsat on last ecm but seems to coinside with what channels are up or down.Other than that Its my only hd source for my hdtv if and when bev comes back.It has gotten better as I get more of a feel for it.I have used the remoted but it does change channels slow.No comparison to my vs xtreme.A few bins ago they did a theme interface upgrade its now cartoony like windows xp.I thought it cool.Bla bla bla hope I helped!
Username: Saqeeb9000
Post Number: 930
seemore butts.. good one...........hahah ...........
Username: Cartier1
Post Number: 1544
well i guess spending $80 is not bad for at least having some ppv even if it works only 1 mounth . but i could not find dvb that will work with my laptab anx has tv out output . i got the dvb-pc today andx i will return it cuz i can in any way use my pc . my house and my tv are away far from the pc . and i dont wanna use wirless stuff to be more safe from poeple around to use mine .
wow i think if emunation and iks has the same risk i will go iks.
the only iks is nfusion or other iks receivers?
Username: Luser
If you can find a good reliable anonomouse proxy program your ip is safe.Just learn the do's and dont's.Like running java It's an IP tattle tale.
Nfusion is starting to sound good.I have heard of something called gbox, key sharing for emulation.Not sure about though.
Username: Dickfoil
Post Number: 88
NFUSION IS BAD...STAY AWAY. ANYTHING THAT IS EASY IS SURE TO GET ATTENTION IF BIG BROTHER
Username: Nydas
Post Number: 6187
cartier 1: Did you buy that card from ebay? And if so, your comments?
Username: Lolol
Post Number: 196
IKS and Emunation sounds complicated. I would just wait for the FTAs to come back up....no rush....I can wait!
Username: Cartier1
Post Number: 1546
nalyn i did not buy the card from ebay . electronic store next to my house ordred it for me this way i can return it to him if i changed my mind . in fact i got the card and i return it unopned cuz my pc dont have the requierment for the card to work . the processeur is less than 1ghz. cuz i dont use it anymore . but i do use only my 2 laptab that i still did not make up my mind on wich usb card i will buy . i will let you know of any news.
Username: Cartier1
Post Number: 1547
i dont iunderstand why my computer that has s-video dont work with my tv . i tried to play a dvd and connected it to the tv through the s-v connection and i got no picture. i dont know if im missing something ?//thas why i still dont wanna get usb card and be in trouble on how to connect to my tv. any help will be appreciated . thanx guys
Username: Thadragun
Kingston, Ontario
Post Number: 42
Two possible reasons I can think of cartier1. It could me simply the dvd program your using is blocking the video because of macrovision. Some programs do that.
Or maybe it's your TV-out settings. Do you get sound and just a black screen on the TV? That happens to me sometimes.
It's different depending on your video card of course but on my ATI card in the settings and go to VIDEO and then THEATRE MODE. If its on standard it shows the black screen. If I change it to THEATRE MODE, or SAME ON ALL I see picture. Some cards you have to choose CLONE.
Hope that helps
Username: Merk
Post Number: 22
cartier1 i have a dell and it has a video driver with software that has the option of changing the video output on my keyboard the f8 button has crt/lcd printed on it if i remember right it has been a while since i used it but i have in the past used the svideo on my tv you hold the fn key and the f8 button at same time and that turns on or off the svideo
