what will be needed to fix current ecms
Username: Brucester
Post Number: 841
what will be needed to fix current ecms,and a very,very basic time frame.
ok guys,here is the easiest way i can put this so all understand.
1.RUMOR (its probably a fact. Just haven't confirmed it yet)
is that DVB- emutation is no longer open source.
if this is true,then your not going to see any more quick fixes.
what many where doing where using the info from emutation to make their quick fixes.
this is not a bad thing however for the long term.
you might see some temp patches here and there,but i wouldn't count on it.
2.what is NEEDED one way or the other.is full emu.full emulation of a card that subs use.this is ALLOT of info.its not going to happen overnight.NO coding team that i know of has set a file expected size on this yet.
so flash rom size requirement is yet to be known,as far as i know.
3.luckily before all this started in,there where some coding teams already working on this full emu.
4.coding is not really anything that should have a time frame set on.
I am not going to guess.
BUT one coding team has set a ruff time frame.pansat coder-blacklist/team blacklist as said hopefully in 2 weeks.but claims pretty certain it will be this month at latest.
hope this helps.so don't expect files to start showing up any more left and right.most if not all coding teams probably are not even going to try,as it would be a waste of time,as the patches where good for a day or two,sometimes less,and take away from the real task at hand-full emu.
got this info from completefta dot com
Username: Fredfarmer
Thanks man, you cool
Username: Pulp_fiction
Post Number: 836
if this is true
Very true !! unlike little miss tiger woods reports TRUE coders do share in open on many forums.... the craptop wannabeee coders are the monks... well they reaping what they sow Nothing=Nothing...
Thats why all the craptops down right now they are clueless on the the dynamic timing routines and where feeding off of mfong and no1 which have put a hold on releasing latest source which has work arounds for map3e..
But latest emunation has been reverse engineer and a dissasemble of the code is floating around on the net.... which will help craptops out just a lot harder for them......
Not going to happen any time soon if ever... there is not enough information availabe on 102 to have a full emu and most stb's couldn't even hold a uncompressed version if there was...
money machine want to sell boxes they will say anything...promise anything....
I still laughing woods (aka new lk) hows ur little bubble world of denial now.....
seem like it going down like I have been saying it was going to......
Username: Oleg1474
Florida Usa
Post Number: 723
Good news!! my program (EUROECM666)ViewSat work good pass all test BL.DishNET (NAGRA-3 coming soon!!)Thank you!! Oleg PHD.
Username: Pulp_fictionass
Post Number: 41
first get on your knees and then close your eyes and open your mouth then I will install the keys for you
Username: Bomberman
Post Number: 84
LOL OLEG DUMBSHIT
