RTA on your pc
-apem
Post Number: 16194
does anyone know where i can get a RTA software?
i was thinking getting a decent mic for my laptop and i can run that software. then use it to fine tune my sound system.
Username: Nd4spd18
Northwest PA
Post Number: 4703
http://www.trueaudio.com/rta_abt1.htm
I use that software. I went and got the crack for the full version
I use a Behringer ECM8000 mic and Behringer UB802 mixer as a preamp, as TrueRTA recommends on their FAQ page. From what I hear though, you can get a ordinary preamp for less than the mixer.
-apem
Post Number: 16206
looks cool.
i was actually looking for something more simple. something i can just us my pc mic with. lol. but i guess if i want to do it right, i have to have the right equipment.
Username: •cam•
BC Canada
Post Number: 1334
Would a mic produce different amplitudes at different frequencies, given a set volume? Specifically, a cheap mic.
Username: Nd4spd18
Northwest PA
Post Number: 4725
A cheap mic will not work.
You have to use a mic specifically designed for these measurements like that Behringer.
