Gold Member Username: CblazeRock island, Tenesssee Us Post Number: 1005 Registered: Sep-07 | i might be getting the zapco 200.2 from thieves in a a week or 2 if everythang goes right if not i will get a diff amp,100 rmsx2 @ 2ohms or 50x2 @ 4 ohms,what would be a good set of components,would really like to get some 2 ohm ones to get more wattage but i guess if not 4 ohms would be ok,price range really around a hundred,could go a lil bit more,and im not purchasing off ebay,usually sonic electronix or onlinecarstereo,maybe woofersetc to,first set of components ever,or even amped mids,i dont want a brigt sound if ya know what i mean i want a clean crisp sound |
Silver Member Username: Drant19DUB-C, TX Post Number: 119 Registered: Aug-07 | the only 2ohm components i can think of are the infinity kappa's but they would be pretty d@mn bright. i say wait til you have a bigger budget and get the pioneer premier 720prs. |
Gold Member Username: CblazeRock island, Tenesssee Us Post Number: 1027 Registered: Sep-07 | i wouldnt put that much in a set of components if i had the money |
Silver Member Username: SomedonniedudeIllinois United States Post Number: 595 Registered: May-07 | What do you mean by bright? Not have a good sound, mostly high (no depth)? |
Gold Member Username: CblazeRock island, Tenesssee Us Post Number: 1033 Registered: Sep-07 | its hard to explain.i guess i mean not sounding good |
Gold Member Username: CblazeRock island, Tenesssee Us Post Number: 1038 Registered: Sep-07 | i figured out what i mean i dont like the metal tweeters,like the silk better,that way they sound good listening to all types of music,the metal ones only sound good on rap where the tweeters need to have that brite soundd to them |
Silver Member Username: Drant19DUB-C, TX Post Number: 120 Registered: Aug-07 | bright = mostly high, a harsh sounding tweeter and not much mid bass. |
Gold Member Username: CblazeRock island, Tenesssee Us Post Number: 1041 Registered: Sep-07 | ^^^^yeah |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4879 Registered: Jul-06 | Silk tweeter > metal usually. Infinity's are especially bad. Not all metal tweeters sound that way, but a lot do. |
Gold Member Username: CblazeRock island, Tenesssee Us Post Number: 1044 Registered: Sep-07 | it wouldnt be so hard choosing if they made more 2 ohm ones,unless i just run 2 sets of 4 ohms off each channel,but that would ruin the front stage effect everybody says u should have,never tried it lol |
Gold Member Username: CblazeRock island, Tenesssee Us Post Number: 1045 Registered: Sep-07 | what about these jbl and infinity is all i can find that makes 2 ohm ones http://www.sonicelectronix.com/item_7433_JBL+GTO607C.html |
Gold Member Username: CblazeRock island, Tenesssee Us Post Number: 1046 Registered: Sep-07 | what about these jbl and infinity is all i can find that makes 2 ohm ones,ive also looked at the kappas,infinity higher line do they have the briite sound to? http://www.sonicelectronix.com/item_7433_JBL+GTO607C.html |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4902 Registered: Jul-06 | It would be ok to run 2 sets of the same components. What you don't want to do is run 2 sets of different speakers. |
Gold Member Username: CblazeRock island, Tenesssee Us Post Number: 1052 Registered: Sep-07 | it wouldnt be so bad if they were cheaper lol since u seem to know about components what some good 4 ohms 50 rms components i could get 2 sets of for 150 bucks,or is the budget to small? |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4904 Registered: Jul-06 | Yeah not big enough budget. What you really need is an amp that does more power a 4 ohms. 50w isnt a real lot. |
Gold Member Username: CblazeRock island, Tenesssee Us Post Number: 1063 Registered: Sep-07 | hopefully is gonna be a zapco 200.2 i know there underrated but i am not for sure by how much |
Bronze Member Username: ExigePost Number: 23 Registered: Nov-07 | if you wanna get serious with this stuff....you really need to get AT LEAST 100x2 @4ohms on the amp...125-150 would be preferable though. i would rather get a lower-end solid amp that does more power in place of an expensive zapco that doesnt do much power. |
Gold Member Username: CblazeRock island, Tenesssee Us Post Number: 1067 Registered: Sep-07 | 80 shipped for the zapco bud i aint paying alot for it |
Silver Member Username: Drant19DUB-C, TX Post Number: 122 Registered: Aug-07 | "i would rather get a lower-end solid amp that does more power in place of an expensive zapco that doesnt do much power." x483948359034 |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4912 Registered: Jul-06 | I agree with Exige I actually couldn't find a good 2ch amp at a reasonable price that had enough power for my components. They take 200w each, and I always want an amp with more power than I need (headroom). I ended up getting a 4ch Alpine amp, and bridged it for 250w X 2ch |
Gold Member Username: CblazeRock island, Tenesssee Us Post Number: 1074 Registered: Sep-07 | for 80 bucks u aint gonna get much power,i just want the mids alil bit louder and to have better clarity than a headunit i doubt i could stand more than 200 watts rms of mids,i can stand thousands of watts of bass but mids jus dont need to be insanly loud |
Silver Member Username: Drant19DUB-C, TX Post Number: 124 Registered: Aug-07 | even if u have 200rms to your speakers, you dont have to listen to them at full blast all day long...turn it down lol |
Gold Member Username: CblazeRock island, Tenesssee Us Post Number: 1075 Registered: Sep-07 | im getting the zapco,i learned the hard way,quality amps is a must or the majic smoke can appear ,i might save up a lil more for some better components,even if they are just 4 ohms,i thank a lil over 100 watts rms would be good enough for my front stage |
Silver Member Username: Drant19DUB-C, TX Post Number: 127 Registered: Aug-07 | you can get a quality amp that puts out more watts rms. look on ebay for a refurbished kicker. good amps and come with a birthsheet |
Gold Member Username: CblazeRock island, Tenesssee Us Post Number: 1086 Registered: Sep-07 | i just decided on a kicker 200.2 and focals might as well do it right the first time |
Silver Member Username: Drant19DUB-C, TX Post Number: 134 Registered: Aug-07 | 200.2 wouldnt push much...look atleast into a 350.2 or 550.2 if possible. just my 2 cents |
Bronze Member Username: ExigePost Number: 24 Registered: Nov-07 | quality is a must..but zapco is overkill. here's a very decent $130 option: http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=6097 secondly..you already said you don't want bright speakers....focal and infinity are probably the 2 brightest brands around...if you dont want bright, you're going wrong with the focals. you really need to listen to this stuff before you make a call on it. if you don't want bright like you said earlier, i suggest CDT's...a much smoother sound to them that wont get harsh on your ears. if you're interested in them, feel free to PM me. ive got some pretty good prices on them. |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4931 Registered: Jul-06 | " you really need to listen to this stuff before you make a call on it. if you don't want bright like you said earlier, i suggest CDT's...a much smoother sound to them that wont get harsh on your ears. " ^^^^ Absolutely 100% agreed. Bad idea to buy a set of speakers without hearing them. Also, I run the CDT HDs and they're great. |
Gold Member Username: CblazeRock island, Tenesssee Us Post Number: 1087 Registered: Sep-07 | yea but how much did you pay for your cdt's |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4935 Registered: Jul-06 | $330 Best set of speakers I've had in one of my systems. |
Gold Member Username: CblazeRock island, Tenesssee Us Post Number: 1091 Registered: Sep-07 | ive got other stuff to worry about then paying 300 bucks for some speakers,i gotta get the headunit,amp,speakers, ho alt,big 3,0 gauge wiring,this all aint going in till next year but is still alot of money,and im guessing cdt's cheaper series arent like the expensive ones? |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4938 Registered: Jul-06 | No but they are still better than Infinity or those JBL |
Gold Member Username: CblazeRock island, Tenesssee Us Post Number: 1093 Registered: Sep-07 | well like i said i just want it to sound better than coaxils would on a headunit |
Bronze Member Username: ExigePost Number: 25 Registered: Nov-07 | CDT's EF series isn't nearly that expensive. i can't list pricing info here but you know where to send PM's for prices. hefty sale today anyways. |
Silver Member Username: Drant19DUB-C, TX Post Number: 137 Registered: Aug-07 | cdt>infinity any day... spend the lil extra money for some QUALITY. it would suck to get your whole system installed and then realise "f\ck...i should have gotten better speakers or bigger amp" get it right the first time... |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4958 Registered: Jul-06 | Yea. Especially the component speakers the most important part of the system....... |
