i need some help setting up my vs lite to pick up bev i have dn already and i setting up a second dish to get bev can anybody tell me how to setup in the vs menu antenna setup
ok wait i have dn also so i think my port 1 and two are taken can i use 3 also iam using a single lnb antenna to pick up 91 what should i use as lnb type and my last question is iam gonna start to angle it now if i set it to tone burst will it let me know recption stregth
which ever port you wanna use to connect your bv dish to. If you use port2 select 2. doesn't have to be a specific one. as long as the software matches what you actually connect it to. i scan transponder 12224. it's just slightly left of 110. hope this helps. go to lyngsat to check the channels on 12224 to make sure you are getting the right sat
