SPL Amps
Username: Kaprese
Walstonburg, NC USA
Post Number: 545
This guy in my neighborhood is selling his amp it is a SPL 1200w amp. My question is are SPL amps a good name brand and are they underrated or overrated ? Also would this amp out perform a PA 1600w amp Gothic Series ?
Username: Basebalz13
Moneta, Va Usa
Post Number: 133
i heard that they are very overratted but thats jus what i heard, how much he sellin it for, how old is it
Username: Kaprese
Walstonburg, NC USA
Post Number: 546
he is sellin it for about 100 and he had it for about 4-5 months who makes SPL amps ? and would it be better to stick with my PA amp or get the SPL amp
Moneta, Va Usa
Post Number: 136
hmm to tell you the truth i would save my money and get a kicker amp off ebay how many watts can your sub handle
Username: Kaprese
Walstonburg, NC USA
Post Number: 549
my subs for now are 2 12" JL W0
Username: Kaprese
Walstonburg, NC USA
Post Number: 550
who makes SPL amps
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 867
spl is the name of the brand lol i have never tried them tho,i believe there on the same level as pa
Username: Carguy
Post Number: 6786
From what I've seen in the past, they're low end amps. Maybe not as bad as Sony/Pyramid, but not higher than Hifonics/MTX.
Username: Cblaze
Post Number: 869
the guy at the shop i go to says there decent,he aint had any probs out of them but i have no idea
Username: Extrmndor3
Http://illuzonemu.serv..., ^^^Sick Game
Post Number: 7291
their the same as kole audio, some legacy wich some spl amps share the same board. one of their higher end lines are kinda decent but still overated they share some technologies with the power acoustik ab3000 board
Post Number: 7292
NOTE:
newer models 07 and newer are made and will be made by poweracoustiks
Moneta, Va Usa
Post Number: 138
like i said get a kicker amp off ebay save your hundred you are willing to spend on that amp, what is your budget for it
Username: Cblaze
Post Number: 873
no wonder the fuse rating and power ratings are the same on both brands lol
Moneta, Va Usa
Post Number: 140
http://cgi.ebay.com/NEW-07-KICKER-ZX300-1-300-W-MONO-AMP-REMOTE-BASS-KNOB_W0QQit emZ180195337211QQihZ008QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Moneta, Va Usa
Post Number: 141
http://cgi.ebay.com/NEW-Kicker-ZX300-1-Car-Audio-Amplifier-Subwoofer-Amp_W0QQite mZ150194034153QQihZ005QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Cblaze
Post Number: 877
300 watts is what id put on my mids lol
Username: Cblaze
Post Number: 878
ask him whats the rms on that spl amp not the max,if its rated at 1200 rms id take it b4 i would 300 watts lol
Username: Kaprese
Walstonburg, NC USA
Post Number: 551
I think it's like 600rms mono but the bridge power it just has max 1600w
Moneta, Va Usa
Post Number: 144
yea i know but i thougt that those 12's was only rated for 125 rms??? so i mean thought wire them down to 2 ohms and that put 300 @ 2 ohms
Username: Cblaze
Post Number: 883
well then get what ya want lol
Username: Zacdavis
Beloit, Wi
Post Number: 721
Lol, SPL is Power acoustik, same manufacturer same parts same assembly line.
Kole is also Power Acoustik.
All three are great values. For dollar per watt they're hard to beat.
I would recommend buying these brands with warranty because they are more likely to have problems.
Username: Naledge503
Http://com4.runboard.c...
Post Number: 2447
Is Power Acousik owned by Soundstream now? Reason I ask is cause when I sent in my old a3000db under warranty, the person I was emailing back and forth with had a soundstream email addy.
Post Number: 2462
Thanks for the reply Zac. I thought you were here to help. I already got my answer from Denim. Power Acoustik is parent company to Soundstream.
