NFUSION
Username: Jerkisland
Post Number: 50
Is this true ? NFUSION box don't need fix downloaded manually but they automatically download it ? Can anyone with nfusion box confirm ?
Post Number: 51
Also it is never down.Can someone with nfusion box confirm ?
Username: Rtap
FL
Post Number: 1478
here are nfusion features.hope this helps
Features :
* Mpeg-2 Digital and Full DVB
* Ethernet Port For Self-Updating via Internet ( full wireless support optional equipment required) connects to your home network for PVR capability
* Ultra-Fast Advanced EPG
* Simple Satellite Scan
* Fast Multi-Satellite Search
* Blind Search (Power Scan)
* Extended EPG and Program Reservation through EPG (Timer function)
* Tele-text Support (OSD and VBI Insertion)
* Channel Sorting by Alphabet, Transponder and CAS
* Channel Control by Delete, Skip, Lock, Move and Favorites
* Last Channel Memory Function
* Total 4,000 Channels (+/-)
* TP CH Auto Update
* Xcrypt Software Support
* RGB Component Video Output
* RCA Composite Video Output
* S-Video Output
* SPDIF Dolby Digital 5.1 Surround
* DiSEqC Control Version 1.0, 1.2 and USALS
* Powerful Channel Control by Favorites, Loc, Skip, Move and Channel Sorting by Alphabet, Transponder
* 10 Languages (OSG and Menu): English, Spanish, Portuguese, French, German, Turkish, Arabic, Parsi
* Plasma Friendly ( No Burn to Plasma TVs)
* Parental Lock/ Installation Lock/ Receiver Lock
* Zoom-In Function LNB/TUNER
* Input Frequency 950~2,150MHz
* RF Input level -65~-250dB
* LNB Control DiSEqC 1.0 & 1.2
* LNB Power 13/18V (MAX, 400mA )
* LNB Tone Switch 22KHz + 2KHz ( 0.6Vp-p)
* External RF Switch 0/12V(50mA)
* DEMODULATOR
* WAVEFORM QSPK (SPCS,MCPC Capable)
* Symbol Rate 2~31Mbps MEPG
* Transport Stream MEPG ll
* Video MEPG ll Main Profile/Main level
* Audio MEPG-ll Layer l & ll VIDEO
* CVBS 1Vp-p into 75 ohms
* Video Format 16:9 4:3
* Frequency Range 5Hz to 5MHz AUDIO
* Sample Frequency 32/44 1/48KHz
* Frequency Responce 20Hz~20KHz HI-FI Quality Digital Stereo
* Audio output 2V rms into 600 CONNECTORS
* LNB INPUT F-Type IEC 169 Female
* Loop F-Type IEC 169 Female
* TV ANT IN F-Type IEC 169 Female
* TV OUTPUT F-Type IEC 169 Female chan 2/3
* S-VIDEO
* ETHERNET 10/100 (Internet auto update (Software upgradeable via INTERNET) or RS-232C cable ) (Wireless using external equipment optional)
* RCA JACK CVBS AUDIO L/R 0/12V
* SPDIF OPTICAL
* Componet VIDEO Y Pb Pr
* SERIAL PORT RS-232 D-TYPE APPLICATION SYSTEM
* PROCESSOR MIPS ( 120 Mhz )
* DRAM 16X 2 MB (Faster than 32 MB of SDRAM)
* LED DISPLAY 4 Digits
* GRAPHIC DISPLAY 720x576
* SUPPLY VOLTAGE Free voltage (100-240V AC 50/60Hz)
* POWER ON/OFF Switch ( Back / Front)
* OPERATING TEMP. -10 C +50 C
Post Number: 52
Thanks for the reponse RTAP but does this mean that NFUSION box is never down ?
Username: Extremex
Post Number: 72
No it does not mean it never goes down. But when it does its only about 2-4 ours before it is back up, sometimes a lot quicker.
It is currently up on both providers using IKS.
Username: Space_invader
Andromeda M31
Post Number: 327
As long there is fix available for it to download, it will continue to work for DN and Bev... No fix, no dn or bev...
Username: Tale
Post Number: 58
Does it mean that NFusion "Coders" have fix we don't ?!?
Username: Extremex
Post Number: 73
Yes, but using IKS, not a stand-alone bin. I suggest you read up on IKS.
Post Number: 53
Thanks, where can I find info on IKS ? I tried Google but it was of not great help.
Username: Tale
Post Number: 59
It stays updated via IKS (Internet Key Service) using the same internet connection as your home computer !
Username: Tale
Post Number: 61
Can anyone confirm that GC is up via nfusion ?
