What's working with what bin.............post here
Username: Saqeeb9000
Post Number: 870
what's working with what bin.............post here
Username: Satgrl
Post Number: 1070
well theres nalins post saqeeb so far these are working......... with bev only...
These are all BEV fixes. Not for DN
SONICVIEW
Sv_1000_0280P Fix for BEV ECM
SV_4000 latest Bev ECM Fix
VIEWSAT
VS Platinum/Lite DBPSW-071217P Bev Fix
Dbpsw-071217p Bev Fix
Vspro-071217a Bev Fix
VS Ultra PFTAUSW-071217U Bev Fix
Pftausw-071217u Bev Fix
VS Xtreme DBPSW-071217X Bev Fix
Dbpsw-071217x Bev Fix
VS 7000 PVRW_071217a Bev Fix
Pvrsw_071217a Bev Fix
VS 9000HD PFTAHDSW-071217H Bev Fix
Pftahdsw-071217h Bev Fix
CAPTIVEWORKS
Cw600sv1.55 12/16/2007
B3V Fix
Cw600pv1.62 12/16/2007
B3V Fix
cw3000-sc-update-12-16-a 12/17/2007
Fix bev and it is on the ftp.
Cw700sv1.36 12/16/2007
Bev Fix
Cw800sv1.36 12/16/2007
B3V Fix
BUZZ
Duo/Trio/Mini Patch (Dec 15,2007)
Bev15exx.zip Fix for latest Bev ECM's
Post Number: 871
Welcome: Dec 17 Bev fixes released for CaptiveWorks, Viewsat, Sonicview, others should be soon....Still only 'basics' for DN
Username: Satgrl
Post Number: 1071
u right yes
Post Number: 872
ok
Username: Thakkar2000
Post Number: 135
so does basic DN work with 227 (converted flu)???
Username: Nydas
Post Number: 6081
DN does not work for Internationals and PPV and P0RN - Since New keys in DN ID 0106 on Friday afternoon.
The latest fixes of today for BEV - Sonicview, Viewsat, and CaptiveWorks have stopped working since activation of new Key 01 unde BEV ID 0907
Good news for those using DVBcards,
The latest release of Emunation software has opened out DN.
Apart from that nfusion, Tessat are working under IKS.
Username: Pulp_fiction
Post Number: 794
Will u give the damn Keys a rest...
its Not KEYS it's a algo issue dealing with the timing of execution times on map routines call that keeps callin the black screen of death into the house...
and EMUNATION has not been confirm working...on any 106's just 101's
Username: Birdwatcher
Post Number: 577
wow this is good to know nyda, its all clear now. thanks for being so smart.!!!!
Username: Nydas
Post Number: 6085
Pulp: I do not htink I will give keys a rest till such time as the ID 0907 and 0106 are eliminated or brought in to user alterable area by the coders.
I alerted people here on Friday afternoon when DN 0106 changed and the DN ECM started soon after that.
This morning BEV introduce new keys 01 for ID 0907 and activated them - earlier for certain areas and for whole of North America, this afternoon.
I have had the previledge of working on developing "Evaluate" function using assembler and C, and what is easy on interpreted code is damn difficult on compiled code, and that is what the coders are facing - what you people are calling "dynamic code" execution.
Post Number: 798
tell u what go grab uself a copy of
winhex and u can edit all the DAMN keys u what in the bin themselves.... lets see where it gets you...
LINUX and EMUNATION user always have access to the keys since they are text file based... yet the suffer down times which each new ECM...
So for that last time it's not the damn KEYS
u get half credit for this... in the sense the converion is like that of porting a OS from one processor to another and yes thats hard..but Without real schematics of the card's implementation of ISO 7816, its a pretty difficult job to know what each (MAP) is doing and to date they have been using brute force attacks to figure out the routines inorder to adjust for the execution times it takes to process the map fuction which dn and veb have now begun to use in processing vid
Username: Nydas
Post Number: 6088
As I said before. when th ecoders have solve the problem, they will have brought the new PIDs to the user - direct like the 0101 and 0901, and will be giving a few extra hex numbers to put in (in conjuction) for the benefit of the new MAP calls and the dynamic routines. That is the route the coder will most likely go for and will be an effective solution - part code and part brute force.
When I see that in a new BIN then I will know that something similar to the breaking (or purchase) of Map57 last year. And I don't think the coders are far behind.
Username: Nusrat
where can i find the bin file fix for viewsat ultra??
Username: Nydas
Post Number: 6093
Spartan: Read a couple of threads here.
Username: Ariza700
Markham, On Canada
Post Number: 24
Nalin,
Just a quicj question ! I have CW600S Premium and I have been setup for DishNetwork. I know the file is out for BEV (V1.62), Can I use the same hardware to see BEV chnnels, do I just need to change the keys ? what do I need to change in order to get all Indian channels ? thx for you help
Post Number: 801
Emunation all ready back up on veb... They are using the same mecm as dish now so use the prov 0101 emu
Username: Leines
Post Number: 36
bev fix from this morning is down... you would need to reaim your dish at bev sats i believe 82 to get indian channels..
Username: Ariza700
Markham, On Canada
Post Number: 25
Leines/Pulp Fiction/Nalin
Ok...In order to use the BEV I will need to point my dish to different satellite. Please correct me if I am wrong, the difference b/w DN & BEV is following :
1) DN is American & BEV is canadian
2) Both point to different sats
3) One can use the same H/W for both D/N & BEV but will need to adjust the dish to point to right sat ?
Thx for your help and co-operation
Username: Nydas
Post Number: 6098
If your DN dish has 110/119W then you are almost setup. Swing the Dish 28 degrees to the East. A bit of vertical shift will be needed. The same LNB combo will work. Do new setup in Antenna setup (110W settings to 82w and 119 settings to 91 w).
Note that
1) BEV is down now and
2) 82W is mostly HD channels.
Username: Laurad
Post Number: 62
Hi, I wondered if all DN set went down. I have converted 2500a, It was working but not on PPV or the other channels. Now it completely says no signal ..Tried to to do Power scan, still no signal. Are all down?
Username: Mrsofty
Platinum VIP Member
Post Number: 97
no signal is a different issue check your cables
GetDSS.com
Username: Donnie1973
Post Number: 2248
I wouldnt switch from dn to bev at all!!! Read around the forums... bev is down most of the time now. If u are not that familliar with it, moving ur dish can be hard. Even if u do get bev... it will go down soon. DN much more stable now.
